Results 1 to 6 of 6
Thread: 484 DME EWS 2 code location?
    Carpentersville, IL
    95' 540i/6
    So my EWS decided to stop working and I now need to bypass it. I know the standard practice is to get a 404 DME and that is what I will probably do (Thanks MYKK for clearing that up) but I started thinking...
    Where is the EWS code saved? Is it on the coding chip or on some EEPROM on the PCB?
    If it is on the chip could one simply replace the chip with one that does not have EWS and therefore not have to replace the 484 DME?
    Sent from my SAMSUNG-SM-G890A using Tapatalk
    Oct 2014
    Prescott, Az
    '95 540i/6
    It's in the binary code in the DME chip. I'm working.on finding and disabling that code to essentially turn off ews in 484. But it's gonna take time. 404 and 484 chips not interchangeable
    Carpentersville, IL
    95' 540i/6
    Ahh ok thanks. I figured haha
    You wouldn't happen to know if Dinan performance chips for 484 disable EWS do they?
    Oct 2014
    Prescott, Az
    '95 540i/6
    I've got about a dozen spare 404 DME's, I've UV erased the chips. I can burn a stock 540i/6 404 tune on a chip, install and send ya a 404 DME with the manual trans tune.
    Maybe send me your 484 manual DME in exchange so I can read that chip and add to my collection .
    You'd still need to bypass the ews module behind the dash and cut & leave unplugged the green wire at pin 66 in the dme harness.
    Carpentersville, IL
    95' 540i/6
    Quote Originally Posted by Mykk View Post
    That would be Awsome!!! PM me and we can work out the details.
    Oct 2019
    UK
    E28,E38
    Hello. 1 have 484 ecu, silver lable in my 1996 e38 m60b30. I got chip with deleted ews, but my car wont start with this chip. (Got from ebay, seller said that is 100% working)
    What i need to do to start my car? I dont have any green wire in pin 66. Car cranks but wont start, with stock chip everithing ok.
  1. Ews-dme sync code
    By kabstyle in forum Diagnostic Software
    Last Post: 09-19-2017, 03:59 PM
  2. E39 DME+EWS in E38, coding problem
    By Inf161 in forum Diagnostic Software
    Last Post: 02-21-2015, 01:18 PM
  3. ews chip location in dme 7.2
    By ronaldino77 in forum 1996 - 2003 (E39)
    Last Post: 04-30-2013, 11:13 AM
  4. Erase EWS Code on used DME
    By mahoubi in forum Diagnostic Software
    Last Post: 12-27-2011, 01:37 AM
  5. DME/EWS and key coding.
    By anncam in forum 1995 - 2001 (E38)
    Last Post: 02-02-2010, 01:04 PM
