Results 1 to 18 of 18
Thread: NV rods with wisecos??
    Nov 2013
    Hager City, WI, USA
    1994 BMW 325is Coupe
    Just curious if it'd be worth it to run a set of NV rods with a set of wisecos on them. Turbo application
    Mar 2012
    Renton, Wa
    98 m3
    You know or just spend the remaining 500$ and not worry about it.
    By the time you buy fresh rod bolts your only out of pocket 380$ or something for the real deal.
    people are having success with nv rods and theyll work with wisecos. And maybe theyll hold 1000whp..
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
    Nov 2013
    Hager City, WI, USA
    I was just curious because I have a set of NV rods laying around
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by boostedbim View Post
    Well what turbo? I think this is key
    1989 535i - sold
    Nov 2013
    Hager City, WI, USA
    S366. Pretty much the same setup I had last year just a bigger fuel system and a different manifold
    Apr 2006
    Minnesota eh?
    86 325es
    Should be fine. I would recommend a set of ARP rod bolts. The stock non vanos rod bolts have a weird undercut on them.
    Nov 2013
    Hager City, WI, USA
    Yeah that was my plan. And acl bearings. Was gonna go for the stock block m50 record but I don't really wanna
    Manchester, N.H.
    96 332IS 6466 turbo
    I just may have a set of these. Does anyone have measurements kicking around to determine ? These are 135 ? Or 140mm. ? From center to center ?
    Sent from my E6782 using Tapatalk
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    I have a set of used (once) ARP rod bolts id let go for cheap
    Shameless plug...
    Apr 2006
    Minnesota eh?
    86 325es
    They are 135mm center to center, same as an m52, s50, or s52. This is what I have in my junk. M50 vanos are 140.
    Quote Originally Posted by rajicase View Post
    Shameless plug...
    M50's use a different length bolt than an m52/s52
    Manchester, N.H.
    96 332IS 6466 turbo
    The set I have are definitely much more hefty than the M52/S52 rods I've pulled. But I believe without rechecking they are 140mm. Are the m50 vanos 140mm rods also thicker like the NV ones ?
    1996 332IS
    Built 3.2
    Feb 2012
    1995 BMW M3
    Uh, hit it with the impact???
    Nov 2013
    Hager City, WI, USA
    As far as I knew NV rods were a bit thicker. I have a vanos m50 but was gonna beef it up a bit with NV rods I have laying around and wisecos. So do I need the crank from the NVm50 too? It thought the vanos m50 and NV m50 had the same bottom end one just had thicker rods
    Apr 2006
    Minnesota eh?
    86 325es
    The non vanos and vanos M50 rods look identical but the vanos rods are just 5mm longer.
    Left to right M20, M50, M52, K1, Howards alluminum
    Nov 2013
    Hager City, WI, USA
    Hmm interesting. I just always thought the NV rods were thicker from what people have said. Good to know.
    Aug 2017
    Savannah, GA
    E36 M3 Turbo, 2015 GTI,
    Nice to finally see what the K1 Rods look like in comparison to OEM.
    Ken
    95' Dakar M3
    (GT35) 500whp+ and no clue what I'm doing....
    Steedspeed Twin-scroll Manifold, Wiseco 8.8:1 CR, K1 Rods, Supertech Valvetrain, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) Twin-Scroll 1.06 AR, Schrick Cams, TRM Tuning, 6 Speed Transmission, UUC Twin Disc Clutch, HFS-6 W/M injection, Zeitronix, Coilovers, Chassis Stuffs.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    M50NV rods are significantly heavier than K1 or Eagle. Eagle are a tiny bit heavier than K1.
    DeWitt, Michigan
    '97 540i/6, '97 328i
  1. E36 FS 135mm Eagle Rods and Wiseco 9.5 CR pistons
    By BrokenBimmer533 in forum Engines, Performance Parts & Software
    Last Post: 01-17-2013, 09:29 PM
  2. Lemforder Tie rod with different size nut
    By forevernewbie in forum 1991 - 1999 (E36)
    Last Post: 10-30-2012, 11:14 PM
  3. is this tie rod with outer tie rod.? link
    By JE BMW in forum 1991 - 1999 (E36)
    Last Post: 03-05-2010, 10:32 PM
  4. S50 Connecting Rods with Pins and Cir-Clips
    By CosmossM3 in forum Engines, Performance Parts & Software
    Last Post: 12-13-2009, 11:33 PM
  5. WTB: 2002 AT Selector Rod with pin
    By bbejj123 in forum 2002
    Last Post: 03-19-2008, 01:24 AM
