Results 1 to 11 of 11
Thread: Fixing dented/crushed Gas tanks?
    Corona California
    79 320/6 81320i 65malibu
    Wondering if anyone has pulled out dents with suction cups or ? in your gas tanks?
    Both tanks in my 80 have been pushed in some from a tire shop drive on "body lift" - Lift.
    WARNING to new E21 owners - do not let tire shops use these to lift your car for tire work or at least make sure they know what they are doing! These can also crush/bend the pinch rail along the bottom of the body these things lift the car with. And the floor pans - which I have already fixed, I also ask the manger to have the techs use floor jacks, sway bar mounts in the front if the air dam is off and rear subframe mounts.
    https://www.bestbuyautoequipment.com...IaAqwIEALw_wcB
    Always FUN TO DRIVE - Build Thread & Tech info - 79 320/6 track car build thread -- Videos of track car -Adam in car Auto-x video - Start-up video - 4/2011 Adam's TOP BMW time San Diego BMWCCA - 4-5-15 Dyno break-in run new M20B25 - Exhaust Thread - Link
    Houston, Tx
    '78 320i
    My car has various pinch marks around the rail, in addition to having (what I assume) are jack stand points completely shifted and warped. I feel confident jacking the car on the rear and front crossmember and the rear differential-- thats about it.
    You'd think a shop should be able to work that out. What a pain in the ass!
    Jul 2010
    San Jose, California
    E21 320i, E30 325i
    I've taken my E21 and E30 before to America's/Discount tire and they use those type of lifts. Now I need to check for any type of damage like you said. Maybe going forward I'll only take them the wheels instead of the car. That way no need to wait for a bay to free up so faster service?
    '81 E21 320i / '90 E30 325i / '̶9̶2̶ ̶E̶3̶4̶ ̶5̶2̶5̶i̶t (sold) / '15 Toyota XW30 / '̶̶8̶0̶ ̶E̶2̶1̶ ̶3̶2̶0̶i̶A̶ (sold)
    Nov 2007
    Sacramento, California
    1980 BMW 320i E21 M10B18
    Cool
    The Tire company owes you gas tanks, Daryl that's on them , its there negligence.
    Randy
    Corona California
    Quote Originally Posted by 320iAman View Post
    Randy
    Maybe but it was three years or so before I noticed the gas tanks..? My bad.
    Nov 2007
    Cool
    Your good,,its 4 years in small claims court to file or maybe they will own up to there mistakes.
    Randy
    Mar 2014
    Burlington, WI
    '07 e92
    I know you're probably looking for a no cost DIY method but what about a paintless dent guy? I just got my car back from one of them, they took every dent and door ding out for $150 including a pretty big crease in the RF quarter and a dent in the leading edge of the hood that had to be pretty hard to work out. He got all the ones in the rear quarters out by going through the ash tray holes. Can't believe they can work through such small holes...
    "Wally" Casten - 1956 Austin-Healey 100, 1985 M-B 300SD, 1987 911 Carrera, 1997 Triumph T509
    "The more things change, the more they SUCK" -Butt-Head (Mike Judge)
    Aug 2001
    NC
    E30M3,318is,318i,E21320
    My tank also has a dent/crease from using the plug as a jack point. Passenger side tank, but I feel I'll do more harm than good to try and pull it out. It's not terrible IMO but being OCD it bothers me at times.
    88 M3
    91 318is
    91 318i
    83 320is
    08 X3 3.0si
    Montana/Washington
    75 2002 77 323irace 91M5
    My tanks had some big dents in them . I was able to fix them with the tanks in . I went through the sender hole with a long hardwood stick and hammer .
    The dents popped right out after a few blows .
    Aug 2001
    NC
    Quote Originally Posted by hdx View Post
    You know I've had that thought after a few brews in the garage. But it's my only tank and I really hate sheet metal full seam welding . I've degreased it but not POR15 metal prep'd yet. Maybe this weekend if I get around to it, I'll look closer and give'r a go.
    88 M3
    91 318is
    91 318i
    83 320is
    08 X3 3.0si
    Corona California
    I have been thinking of trying this - I will have to give it a go.
  1. Crushed Gas Tank. Removing old need help
    By bolomiester in forum 1995 - 2001 (E38)
    Last Post: 10-30-2020, 05:37 PM
  2. Crushed gas tank.
    Last Post: 05-24-2020, 02:06 PM
  3. Gas tank flap fix for a buck
    By steveng1993 in forum 1991 - 1999 (E36)
    Last Post: 07-16-2007, 08:56 AM
  4. Fixing Gas Tank Vaporization Valve
    By connor014 in forum 1991 - 1999 (E36)
    Last Post: 09-14-2006, 07:38 PM
  5. How to Fix Leaking Gas Tank
    By burton5864 in forum 1991 - 1999 (E36)
    Last Post: 05-05-2005, 04:45 PM
