Results 1 to 7 of 7
Thread: E90 Error Code Help
    Nov 2017
    Australia
    2006 BMW 320D
    E90 Error Code Help
    Not sure if this is the appropriate forum, but looking for some advice on a few error codes generated by INPA.
    After clearing the errors and taking the car for a spin to induce the problem, INPA produces these error codes:
    2B5C
    51A7
    5E1A
    The car goes into limp mode, idles high, and if turned off will only start on the second attempt.
    Any idea what's going on?
    Thanks.
    Nov 2017
    Australia
    2006 BMW 320D
    Is anyone able to help?
    I've found the following from searching google:
    2B5C - crankshaft sensor
    51A7 - gearbox control unit
    5E1A - dynamic stability control
    Could anyone shed any light on what I should attempt first?
    Replacing crankshaft sensor?
    Thanks.
    Jul 2004
    Houston, TX
    36 Cylinders
    When you scan with inpa, it gives you text description of the code. Can you write that here, or screenshots or something?
    Helps if you include what ecu you are scanning. I couldn't find any of those codes for the DDE6 in the 2006 E90s.. but maybe I need to be looking in a different profile.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Nov 2017
    Australia
    2006 BMW 320D
    Hi again,
    Haven't had much time to dedicate to solving this issue. Fired INPA up today to see if I could get more info. From what I've read, the error 2B5C relates to the crankshaft sensor. Can someone tell me if the screengrab "MSD80 error memory lesen..." supports that?
    Should I just go ahead and replace the crankshaft sensor?
    Thanks for any help.
    [IMG]https://photos.app.*******/VaEFRx9ZeeF1E5QQ2[/IMG]
    Nov 2017
    Australia
    2006 BMW 320D
    Sorry, here's a link to the screen shot:
    https://drive.google.com/file/d/1nA8...ew?usp=sharing
    If anyone could help I'd greatly appreciate it!
    Jul 2004
    Houston, TX
    36 Cylinders
    Is this for the 320d?
    Why are you using MSD80 profile for petrol cars?
    -Abel
    Atlanta, GA
    14 F01 750i 14 F10 550i
    Quote Originally Posted by bermanc View Post
    Thanks.
    I had these exact codes with my 2007 e90 328i. The primary symptoms was poor shifting of the transmission and SES was lit. Replaced the crankshaft sensor and all was fine.
  1. Error code help.
    By M3-Play in forum 1996 - 2003 (E39)
    Last Post: 12-30-2007, 12:38 PM
  2. Error Code Help Please
    By Divy in forum 1996 - 2003 (E39)
    Last Post: 03-17-2006, 12:31 PM
  3. error code help PLEASE!!!
    By BuzzLtYr in forum 1991 - 1999 (E36)
    Last Post: 01-25-2005, 08:25 PM
  4. error code help
    By pelos in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-16-2005, 07:55 AM
  5. Need Error Code help!!!
    By dgr71 in forum 1992 - 1999 M3 (E36)
    Last Post: 11-19-2004, 04:30 PM
