Results 1 to 3 of 3
Thread: Ignition coil mounting stud PN
    Apr 2017
    Schenectady, NY
    1995 BMW M3/2/5
    So I just checked realoem and I believe number 5 is what I need PN 07129908103, Its the only one that seems close to the position and there is no stud shown in the ignition coil system on the other blow out diagram. I'm missing two which is rather obnoxious I just don't want to order the wrong hardware. Picture for reference
    Oct 2003
    Seattle
    99 M3
    The valve cover is retained by a combination of #6 and #7.
    #7 is used down the center of the valve cover, common to the coil ground straps.
    The coils are attached on my 2 S52 and M52 are bolts, shown as #4 p/n 07119905400, in this image, image shows a nut, part is identified as a bolt in the listing.
    http://www.realoem.com/bmw/enUS/show...diagId=12_1977
    Apr 2017
    Schenectady, NY
    1995 BMW M3/2/5
    Quote Originally Posted by bluptgm3 View Post
    So it's safe to assume the same studs retaining the beauty cover would be the same as the 12 that the ignition coils mount on? That's where my confusion was because the ignition coil blow out diagram only shows the nut that's used to secure the coil packs once they are on the studs
    Sent from my SM-G955U using Tapatalk
    My mistake I re read your post. The image just shows a nut but it is indeed the stud bolt
  1. LHS ignition coil mount
    By jeffbebe in forum 8 Series (E31)
    Last Post: 08-10-2017, 08:29 PM
  2. ignition coil stud replacement
    By jrusso628 in forum 1991 - 1999 (E36)
    Last Post: 02-09-2015, 09:52 AM
  3. Replies: 0
    Last Post: 12-02-2013, 02:07 PM
  4. Ignition Coils : PN 12131748017 / 12131748018
    By Captain Morgan in forum Engines, Performance Parts & Software
    Last Post: 10-18-2008, 01:13 PM
  5. Need PN# for slave cyl mounting stud??
    By Eric1H in forum 1992 - 1999 M3 (E36)
    Last Post: 12-16-2007, 11:52 PM
