Results 1 to 7 of 7
Thread: No power steering after replacing pump twice
    May 2012
    San Diego, CA
    1996 BMW 328is
    1996 328is, 140,000 miles
    I've owned this car for 17 years, and do most of my own work.
    Originally, the power steering was working great, but the pump made a loud squeaking noise at idle.
    I installed a used pump. No squeak, but immediately no power steering. I bled the system (lock to lock several times). No power steering.
    I was frustrated, so I thought the pump was defective, so I went to get another pump.
    I went to a junk yard today. I paid $13 for another pump. I installed the pump, bled the system (no noise during bleeding), and still no power steering. No change from the first replacement pump.
    Therefore, it was not the first replacement pump.
    I have a hard time believing that I have a bad steering rack. Everything worked great prior to installing the first pump. I do not see how changing the pump would make the rack go immediately bad.
    The only other variable here is the fluid. I used ATF fluid Dextron III (Super Tek) from Wal Mart. Prior to changing the rack, maybe change the fluid? What fluid would you recommend?
    Opinions? Help?
    Brian
    Oct 2003
    Seattle
    99 M3
    The reservoir contains a filter, have you changed the reservoir/filer?
    Change the reservoir to change the filter.
    TX
    E36 P38
    When you say you bled the system by going lock to lock, did you actually hold the wheel against the lock? If I understand it right, you need to hold the wheel against the lock on either side several times to bleed air out.
    May 2012
    San Diego, CA
    1996 BMW 328is
    @bluptgm3
    No, I didn't. How do I do that? Do I need to change the whole reservoir?
    @smickler
    I will give that a try.
    May 2012
    San Diego, CA
    1996 BMW 328is
    When I disconnect the hose that goes from the reservoir to the pump, I should expect all of the fluid in the reservoir to gush out. Correct?
    It is not. It is barely dripping.
    Is there a screen or a filter in the reservoir? If so, how do I clean that?
    Brian
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    A new reservoir is $20. If that is your problem. One of the reservoir lines has a restrictor in it. It’s about an inch long, solid metal with maybe a 3/16 hole drilled through it. Located in the middle of the line. I wonder if that is clogged? If pulling the reservoir to check for flow maybe also pull the lines but nite that the one with the restrictor will flow much less.
    Oct 2003
    Seattle
    99 M3
    Ya, good point. Disconnect the return line a pass a piece of wire (coat hanger wire) thru the restrictor to be sure it is not clogged.
    Replace the reservoir/filter.
  1. Replies: 7
    Last Post: 09-25-2017, 08:17 PM
  2. No power steering after rack change
    By Hellmet in forum 1999 - 2006 (E46)
    Last Post: 04-20-2016, 07:35 AM
  3. Replies: 0
    Last Post: 10-20-2014, 01:32 PM
  4. no power steering after ATF flush
    By rejected in forum 1991 - 1999 (E36)
    Last Post: 09-17-2009, 03:32 PM
  5. Power Steering out....replacing pump
    By bevo323 in forum 1999 - 2006 (E46)
    Last Post: 08-07-2009, 10:13 AM
