Results 1 to 6 of 6
Thread: Ground Control Street Camber Plates
    Jan 2016
    USA
    1995 M3 Coupe
    I thought I'd share my experience with the GC Street Camber plates since I've read plenty of inconsistent posts about them.
    I purchased a pair from Bimmerworld and they sent me the wrong spring hats. I called Ground Control and they promptly sent me the correct hats for free, I put the incorrect ones in the box and sent them back to Ground Control. Their service was excellent, and I was surprised they helped me out considering I didn't purchase the plates direct from them.
    I just parked my car for the winter after putting 9k miles on the plates this summer, and they seem to be performing quite well. NVH is unchanged from fresh OEM strut mounts and the camber adjustment range was plenty for my needs. I only drive my car on the street so a quiet camber plate was a requirement.
    The only gripe I had with them initially was their compatibility with OEM strut reinforcement plates. I cut off part of the inner lip of the reinforcement because they seemed to restrict a small range of adjustment. However, this proved to be unnecessary as my alignment specs didn't require the full range of adjustment.
    I hope this helps anyone considering these plates. They're well made and perform as advertised. I'll be sure to update as I continue to put miles on them.
    Aug 2017
    Langley, BC
    95 M3 S52
    Thanks for the review, just picked these up used and GC was willing to sell me the parts the seller forgot to give me. By compatibility with oem plates and the range of adjustment, i'm guessing at max -1.5 degrees it wouldn't work with oem plates?
    Aug 2013
    1999 BMW M3 Coupe
    Yeah compatibility with reinforcement plates is a common issue with many camber plates. They aren't really designed with them in mind, and honestly the steel in the camber plates serves much of the same function. Some amount of tweaking is usually needed for fitment with any camber plate.
    I own the GC hybrid street/track plates and am also quite happy with them. NVH is fine for a street car. They can groan a bit when the bearings get gunked up, but I clean and grease them a couple times a year to prevent this and it seems to work well. As far as adjustment goes, I'm able to get to -3.5 degrees on both sides which is pretty close to maxed out on the plates. Max is probably around -3.75 in my case, before the adjustments hit the edge of the shock tower opening.
    Jan 2016
    USA
    1995 M3 Coupe
    @Ribosome I can't speak exactly for the adjustment range. I used a single washer between my strut bolts to get a little camber before I got the plates. Also, my car had an unusual variance in its alignment between sides and I have yet to figure out the source. So I retained the camber washers and I was able to get my desired -1.8 degrees per side and I'm sure I could get significantly more if I wanted. Your results will likely be quite different.
    Jan 2017
    Kitchener, Ontario
    1999 BMW M3 Convertible
    Quote Originally Posted by Ribosome View Post
    I aslo have GC street plates and without any modifications I run -2.5 degrees per side and it's not maxed out in the camber plate or contacting the reinforcement plates yet. I do have a relatively low ride height but its far from slammed.
    Summer Daily -- '99 E36 M3 'vert 5MT
    Current Project -- '97 E36 328is Coupe 5MT
    Aug 2017
    Langley, BC
    95 M3 S52
    Quote Originally Posted by dlhjimmy View Post
    Quote Originally Posted by gingerELITE View Post
    Thanks guys this was really helpful. If i remember, I'll update you guys in December when I install my koni yellow/oem springs/gc plate combo and get an alignment
  1. Ground Control Street Camber Plates Z4/Z4M/E46/E46M
    By BTM in forum Suspensions, Springs & Shocks
    Last Post: 03-30-2012, 10:40 AM
  2. E46 Ground Control Street Camber Plates for E46 M3
    By turbof128 in forum Suspensions, Springs & Shocks
    Last Post: 09-13-2011, 12:26 AM
  3. FS: Ground Control Street Camber Plates, Eibach ERS Springs
    By Project SSAP1 in forum Suspensions, Springs & Shocks
    Last Post: 11-20-2009, 11:47 AM
  4. FS: NEW Ground Control Street Camber Plates - E36 M3
    By M3LaRue in forum BMW Parts For Sale
    Last Post: 04-23-2006, 10:47 AM
  5. FS Ground Control Street Camber plates for E36 M3
    By BJO in forum BMW Parts For Sale
    Last Post: 02-12-2004, 03:55 PM
