RM European Auto Parts
Results 1 to 20 of 20
Thread: Completely dumbfounded long crank no start
    Nov 2017
    modesto
    2007 bmw 335i
    Unhappy Completely dumbfounded long crank no start
    I've been on this forum many times before, which has helped me diagnose my problems, but i'm in serious need of some help.
    I have a 2007 335i, automatic.
    Car was driving fine, when suddenly, it just showed a half-engine light, with my car then turning off.
    In addition my car battery light flickered on.
    I have one of those cheap code readers, and it's throwing out so many codes at once. one of them
    being p1417 fault code.
    symptoms go as follows:1st attempt long crank, starts, but idle goes up and down from 1000 to 1500 rpms. 2nd attempt, long crank, no start. Lights still turn on.
    p1417 fault code. Bank 1 codes (there were so many relating to bank 1 codes, but had to abandon car at shopping center)
    Parts replaced relating to possible problem: starter replaced less than a year ago, as well as the crankshaft position sensor. although i will note the crankshaft position sensor i found on a site that had it fairly cheap, it wasn't a perfect fit by any means, but this has worked for over 4 or so months.
    I am absolutely frustrated how many times i've had to diagnose my car, but with over 10 codes being thrown, I don't know where to start.
    I plan to take it to a reputable mechanic, but i would like to fix my car to the point that i can drive it there.
    Additional info: ive had the car since 2013, and i have never replaced the battery, and today was the coldest day here where i live (central valley in ca)
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Welcome to the Forum!
    Quote Originally Posted by Noop Noop View Post
    Well I for one, and many other Tech's on here do not trust any generic "P" codes. If you plan on DIYing your car, you will need to find a buddy/friend or get a proper diagnostic tool. While you are looking at the $150 range, how much would it cost at a shop to pull all the codes from all the DME's?
    I would suspect the crank position sensor, for a cheap one would last about that long. Only 3 name I trust when it comes to OE sensors: Bosch; Hella; Siemens. All are made in Germany and BMW sources from those 3 manufacturers for most of their sensors.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Nov 2017
    modesto
    2007 bmw 335i
    ive been meaning to order the scan tool that's on the ecstuning site, but i've been struggling to catch up on some overdue bills. that being said, i'll ask the mechanic how much it would be to do that. i'm still trying to figure out what my next move is, for example, if maybe i should just order a new crankshaft sensor and go from there.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    I agree with Darin. That el cheeeepo crank sensor is the most likely cause of the problem. Bite the bullet and install a crank sensor made by the supplier to BMW.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    For a capable scan tool, Look at the go well nt510. About $150 and you can download on free brand specific module when you register it. Does abs, adaption, steering angle sensor, pending codes, etc
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    A crank sensor that "wasn't a perfect fit"? Now, THAT is a scary thought!
    https://www.fcpeuro.com/products/bmw...or-s119044012z
    and the o-ring:
    https://www.fcpeuro.com/products/bmw...-12141748398oe
    Chris Powell
    BMWCCA 274412
    Charleston, SC
    '15 I01Rex , '11F25
    Long crank no start on an n54,if its not the cheapo CPS, my guess: high pressure fuel pump.
    Nov 2017
    modesto
    2007 bmw 335i
    im going to stop by the dealership and just order the thing, i meant to buy one that wasn't a cheap cps, but completely forgot about it, as well as look up that scan tool. a lot of good info, will follow up once i get the part in and install.
    Joppa, Md
    99 M Coupe,04 K1200rs
    "dealer!"
    You can buy a good one elsewhere,Pelican,etc.
    Nov 2017
    modesto
    2007 bmw 335i
    So in my attempt to be thorough, I got a ride to my car, waiting for the tow truck to arrive, and now have the full list of what this scanner is telling me. It goes as follows:
    1) camshaft position sensor A circuit bank 1 or single sensor, 2)CPS sensor B circuit bank 1,3) throttle valve position control; stuck temporarily, 4)throttle valve position control; throttle stuck permanently,5) p1417,6) p3003, 7)camshaft position sensor A Circuit intermittent Bank 1 or a Single Sensor, 8)CPS sensor B Circuit Intermittent Bank 1, 9)Throttle Valve Control Circuit
    Sooooo maybe it's not the crank sensor? Either way I know I'm going to replace it, just wanting to know if I should look at replacing the camshaft sensors first, or if these are symptoms to something worse
    New York
    1974 2002, 2009 128i
    The first thing you need to do is get a BMW-specific scanner on it. Fault codes reported by OBD2 readers are incomplete at best and inaccurate at worst.
    Life's tough. It's tougher when you're stupid.
    -John Wayne
    Nov 2017
    modesto
    2007 bmw 335i
    Okay, well I bought the foxwell nt 150 code reader, and I'm still trying to figure this thing out. I believe it says under status report, A0B4/present: CAS: engine start, starter operation
    And
    A0B2/not present: CAS: supply, terminal 30e/30l
    Nov 2017
    modesto
    2007 bmw 335i
    Also under testing the jbe: it reads A6E4/not present fuel level sensor, left.
    I had replaced starter months ago, but would that code be stored unless deleted?
    Aug 2017
    Menlo Park
    '05 ///M3
    Erase/clear all codes and rescan. Some of those codes might have been there for years.
    Jun 2002
    E39M5, E500 4WD
    +1, to clearing and rescanning....and good job, getting the BMW specific scan tool.
    The N-5x generation engines will start, with a bad crank sensor....after a long cranking time; and they will display the Service engine soon light, and set a crank sensor code, if that happens.
    You need to be extremely careful, replacing this sensor: it can be installed at an incorrect angle, especially if the o-ring is incorrect, or old. Also, be really careful not to over tighten the bolt and break it. The electrical plug is also delicate, be careful.
    I'm quite sure that a bad cam sensor will also cause a long cranking time, and should set a code pointing to exactly which cam sensor is bad.
    After clearing all codes, drive the car half way around the block; shut it off, restart, and drive home and check the codes again. Act upon whatever codes you find then.
    But by all means, replace the cheap crank sensor right away.
    Chris Powell
    BMWCCA 274412
    Nov 2017
    modesto
    2007 bmw 335i
    Well I replaced the battery, car turned on, idling up and down, and after erasing the codes, I have some of the same codes.
    1)
    A0B4 CAS: engine start, starter operation.
    2)
    Engine-DME
    2E7C: BSD data bus communication fault
    3100: boost-pressure control, deactivation
    2AA2: camshaft sensor, inlet, gap loss
    2a9b: crankshaft-exhaust camshaft, synchronization
    2acb/not present: DME master relay, activation
    2e7c/present: BSD data bus communications fault
    In addition, I keep hearing a buzzing sound, from the motor, just not sure if it's coming from the water pump (since I was leaking coolant, I replaced cracked radiator) and it just keeps turning on every time I turn the ignition to ON,
    Or if it is coming from the motor.
    Jun 2002
    E39M5, E500 4WD
    BSD refers to the alternator charging control via the DME (engine computer)
    Boost pressure control deactivation means that the computer is putting the engine into limp mode, because some crucial piece of data is missing or incorrect.
    Crankshaft to camshaft correlation means that the crankshaft to camshaft TIMING is wrong ! DANGER !
    Inlet camshaft (Gap Loss), I have never seen, but I'd expect it means your timing chain is slapping around, especially in conjunction with the cam/crank correlation code.
    The CAS (starter) code, I'd probably worry about after dealing with the cam / crank codes.
    Have you been hearing a rattling from the valve cover?
    I'd really have to suggest that you have the car towed to an excellent BMW specialist shop, and have them check the cam gear bolts, and the cam timing. If these codes reset right after you cleared them, you have a serious problem. There is a known issue of cam/vanos gear bolts breaking and coming loose. If you catch it in time, you can save yourself many thousands of dollars. If not, you bend all the valves.
    I would advise against starting the engine again, sorry.
    EDIT:
    When you have the car towed to the shop, tell them your brother is a BMW technician, and told you to not start the engine because he thinks the cam gear bolts might be about to break. Don't tell them you read this on a forum.....brother.
    Chris Powell
    BMWCCA 274412
    Nov 2017
    modesto
    2007 bmw 335i
    Yes I have heard a rattling, wasn't throwing any codes so I kept thinking it was normal.
    With my luck, I'm sure I already messed something up.
    Well the only thing I've done is turn on the car, but immediately turn off the car, because I didn't want to risk moving it in the condition it's in.
    The tech I take it to was closed till tomorrow for holidays. I will make an appointment and will have to tow it there, and tell him about not starting the car.
    Jun 2002
    E39M5, E500 4WD
    By the way, I have not seen this on a ~2007 engine, only on '08 and later. I'm hoping that ptarditi will correct me if I'm wrong, and this engine does not use the aluminum bolts here....but I think it does. The problem has continued at least though 2015, with several service bulletins on the subject.
    Chris Powell
    BMWCCA 274412
    dworthy's Avatar
    Nov 2010
    Chris, if it is a late 2007, sometimes they apply the YM-08 stuff to it. I have the same problem with my M-3 as it was built in 08/2004, but it has the updated 09/2004 and up stuff like the CCV for example.
    OP, do not drive this car anymore, you will only do more damage, and that motor is expensive.
    Darin
    Current:
    Past:
    M-Flight Member
  1. E39 slow crank no start. Long post...
    By 4g62 in forum 1996 - 2003 (E39)
    Last Post: 07-16-2019, 06:33 PM
  2. Random LONG CRANK NO START issue, Can anyone help?
    By Dboy7er in forum 1995 - 2001 (E38)
    Last Post: 06-26-2016, 02:20 PM
  3. Long story about crank/no start '06 530i
    By Winterhorse in forum 2004-2010 (E60,E61)
    Last Post: 01-31-2016, 07:16 PM
  4. E32 long cranking to start
    By jim.edwards in forum 1988 - 1994 (E32)
    Last Post: 09-03-2003, 10:11 AM
  5. CRANK, CRANK no start. HELP!
    By martin23 in forum 1983 - 1991 (E30)
    Last Post: 04-14-2003, 03:37 PM
