Results 1 to 2 of 2
Thread: fuel gauge shows empty
    Oct 2017
    Aliso Viejo, CA
    2009 BMW 750Li
    Quote Originally Posted by jeewing View Post
    When you had the car filled up you musta had the key in the ignition. That effectively "locks" the computer in it's current state. DON'T leave the key in the ignition when you gas up.
    _
    Pull fuse #31. Put the key in and forward but do not start the car. Count to five and remove the key and replace the fuse. Some E-36's have had success with fuse #41 if 31 doesn't work.
    _
    Hi,
    My fuel gauge also shows empty. I changed the fuel sender, but it still shows empty. My car is a 2009 BMW 750Li.
    I tried removing all fuses that correspond to the symbol = gas station pump. When I started the car, it shut down after 20 seconds. The fuses must have been for fuel pump. I reinstalled the fuses.
    Could you tell me what fuse 31 (or 41) is for 2009 BMW 750Li? I have the fuse diagram, but I don't know which fuse to remove/test. Also when I remove the fuses, should I just do the ignition or start the car?
    Thanks in advance
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    moved here from E36 forum
  1. Temp gauge and fuel gauge showing strange readings
    By rono190 in forum 1982 - 1988 (E28)
    Last Post: 03-02-2008, 06:46 PM
  2. fuel gauge says empty
    By claudiomack in forum 1991 - 1999 (E36)
    Last Post: 01-10-2008, 09:16 PM
  3. E36 Help needed! Fuel guage shows empty regardless!
    By KyleAwesome in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-04-2008, 12:25 PM
  4. fuel gauge on empty all the time
    By m3608 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-30-2007, 07:48 PM
  5. Fuel Gauge Showing Empty
    By x0rr0 in forum 1995 - 2001 (E38)
    Last Post: 03-29-2006, 12:21 PM
