Bough a set of JT Design rear shock mounts from Turner and am very happy with them, however I read I'm supposed to have two cupped washers(upper and lower) that I must reuse from my old shocks, I only have one, the upper, and could not locate a bottom washer, I can't quite install my mounts unless I have both, could someone shoot me a part number for said washers?
exploded view of old shocks https://www.realoem.com/bmw/enUS/sho...diagId=33_0459
what I believe I need is this bottom cupped washer https://www.bavauto.com/Assets/inst_pages/ins058.pdf
Join the SoCal E38 owners group on Facebook http://facebook.com/groups/officialdistrict7
... and on Instagram @district7_socal
Subscribe to my YouTube for E38 content--> https://www.youtube.com/c/ARPerez
Without the bottom cupped washer I’m not sure how you RSM were functioning.
#6 and #11 from the realoem image you supplied.
Go to ECSTuning and enter those part numbers into their search engine.
Thanks bluptgm3, I ended up going to my local salvage yard and pulling the cupped washers from an e36, they worked perfectly.
For some reason my old shocks came with a metal sleeve sitting on a small washer and it was missing the bottom washer, go figure.
All fixed, thanks!
You re-used the small washer, correct? It is part of the build-up shock.
