Results 1 to 6 of 6
Thread: How to determine how much a cylinder head has been milled
    Apr 2009
    Richmond, MA
    I wondering if anyone had the specs on where to measure and what the measurements are to determine how much a cylinder head S50/S52, has been milled. I just milled 0.010 off of mine, but would like to determine if any had been taken off prior, so I can select an appropriate head gasket thickness. Thanks, Jeff
    Jan 2002
    outta SoCal, now CO
    '98 M3 Alpine White
    The only spec in the BMW docs is new head thickness - 140.0mm .
    Attached Files Attached Files
    See ya later,
    tony
    '98 M3, '92 Dinan3, '05 R1100S BCR, '07 R1200S, Aprilia T
    Apr 2009
    Richmond, MA
    hmm, interesting, thanks! I'll have to poke around with the calipers and see what is close to 140mm... I'LL report back if I learn anything!
    Apr 2009
    Richmond, MA
    yup, just measured quick, this is the overall height of the head! great, thanks again
    Oct 2003
    Seattle
    99 M3
    Total height of head - I think the dimension is 140.000 mm. No machining allowed for S50/52, that said the difference can be made up with head gasket thickness.
    I don’t recall seeing the same “no machining” note for M50/52. My take is that the S50/52 has higher lift that could be a problem if the piston to valve distance is reduced.
    Jan 2002
    outta SoCal, now CO
    '98 M3 Alpine White
    I saw a minimum thickness spec somewhere and I think it was in the AERA data. I'll check it when I get a chance. But there is room to shave the head a bit if there's some runout. Done it many times. My take is that anything that could boost the compression even a little bit could affect the emissions output, especially the NOx on these engines, so they don't recommend any trimming. If you think this is not a concern then remember we got the juvenile version of this engine, not the adult setup.
    See ya later,
    tony
  1. E36 M50 Cylinder Head. Has been pressure tested and resurfaced.
    By IHMNF in forum Engines, Performance Parts & Software
    Last Post: 10-22-2014, 02:30 AM
  2. How to determine how many miles on engine?
    By Ornithology in forum 1991 - 1999 (E36)
    Last Post: 02-10-2010, 06:42 AM
  3. how to determine braking zone in auto-x?
    By BJO in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 08-06-2002, 04:43 PM
  4. how to select cd changer on the head unit...
    By specialk in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 05-29-2002, 10:37 PM
  5. How to determine 95 M3 Camshafts from 325i Camshafts
    By Jesse325i in forum 1992 - 1999 M3 (E36)
    Last Post: 12-13-2001, 01:30 PM
