Results 1 to 6 of 6
Thread: where to look first
    Feb 2017
    Oudenaarde, Belgium
    1989 e32
    where to look first
    problem:
    - difficulty starting (especially after a few days of not driving)
    - when started: rough idle
    - when revving in neutral: no smooth climb in RPM (like he has the hiccups)
    sometimes the RPM gets stuck on 3000 and after a second, he continues climbing
    - when driving in low RPM (1000-1500): impossible to accelerate. car hesitates
    - when accelerating: 1500 to 2500 RPM: no problem, then at +/- 3000 it hesitates and then above 3500 it continues climbing.
    Where to look first?
    - spark plugs?
    - fuel pump?
    - injectors?
    - valves?
    - other?
    Grts
    Pieter
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Pieter, more details please. That is not enough: 1989 e32
    735, 730 with M30, automatic yes/no, if M30: with EML or not? Or a 750 with M70?
    Basically all the items to be checked are here https://www.bimmerforums.com/forum/s...power+ultimate
    Feb 2017
    Oudenaarde, Belgium
    1989 e32
    oh yeah, sorry
    it's an 730i M30 manual with EML
    Jan 2005
    Japan
    I would first check for air leaks, especially on the M30 there are a lot of vacuum hoses, also under the intake. Start the cold engine and spray starter pilot around (not in) intake and all the hoses, if the RPM changes, you have a air/vacuum leak.
    http://www.nmia.com/~dgnrg/hose_map.jpg
    https://www.bimmerforums.com/forum/s...ghlight=intake
    Feb 2017
    Oudenaarde, Belgium
    1989 e32
    Hi,
    I didn't find any air/vacuum leaks, so step one I think is OK.
    Next I tried to check the spark plugs, maybe there's a different color in one or two spark plugs.
    But I didn't get a chance to look because I can't unscrew the spark plugs. They don't move an inch, even my good friend WD40 didn't help
    Before I continue: is it oké that I put my full weight on them to unscrew, or is there an other solution?
    Feb 2017
    Oudenaarde, Belgium
    1989 e32
    So,
    I managed to loosen the spark plugs.
    They seemed fine to me (color wise)
    But the distance where te spark 'jumps' was more than a millimeter (way too much I guess) so I took my hamer and smashed it to 0.6 millimeter.
    Result: smooth idle, no hesitations while revving (for now).
  1. Obvious Leak in Touring Air Suspension - Where to Look First?
    By BimmerM3inGA in forum 1996 - 2003 (E39)
    Last Post: 05-30-2011, 11:06 PM
  2. New to the bimmer scene, need to know where to look for parts
    By JeWRaCeR in forum 1988 - 1996 (E34)
    Last Post: 09-25-2003, 07:51 PM
  3. Business Majors: Where to look for Jobs?
    By ae86_16v in forum Off-Topic
    Last Post: 06-23-2003, 03:18 PM
  4. back-up lights not working. where to look?
    By Tahoe M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 12-04-2002, 06:17 PM
  5. Where to look for e30 M3's online???
    By Focal M3 in forum 1987 - 1991 M3 (E30)
    Last Post: 06-05-2002, 11:47 PM
