Results 1 to 17 of 17
Thread: S52 HAMMERED spark plug, possible rod knock!?!?
    Mar 2013
    Texas
    98' Hellrot M3
    So I've done some research trying to figure out a spark plug issue but haven't found anything on what might be the cause.
    Long story short my friend recently bought a sedan e36 M, car has been running great not even a week into ownership and all of the sudden started miss firing and trying to die not holding idle.
    We did some diagnosis cleaned the ICV and pulled the spark plugs and coils, all looked good but cyl.6 . Seems like the spark plug got hammered possibly by the piston but not sure at the moment as we need to check the cylinder and piston head with a endoscope camera. The ceramic is missing but the ground electrodes are all there.
    Never seen this happen before, anyone have experience with this or any idea what might have caused this?
    Any info is helpful, still have to do more diagnosis on the engine to see what happened.Screenshot from 2017-11-17 22-53-10.pngScreenshot from 2017-11-17 22-53-18.png
    Apr 2017
    Schenectady, NY
    1995 BMW M3/2/5
    Are those quad electrode? I've never seen it personally but I've read of those plugs failing in that manner. Should be easy to see if it made contact with piston. Make sure to check your torque specs on all your plugs these aluminium threads are really finniky with the plugs
    Sent from my SM-G955U using Tapatalk
    Jul 2005
    Indianapolis, USA
    1993 318i Touring
    Make sure that those are the correct plugs and not ones that stick down too far into the cylinder.
    RRSperry's Avatar
    RRSperry is offline Senior Moment Member BMW E36 M3 Expert
    Mar 2002
    Eldersburg, Md
    95 ///M3sc, '21 C8 HTC
    I know I'd be scoping that cylinder. Id also be doing a compression and leakdown test.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Looks like a foreign object got in there or a mechanical over rev, aka moneyshift, bent a valve and maybe broke a piece off that became a foreign object. I agree with sticking an inspection camera down the hole or doing a compression test to see how that cylinder matches the other 5. I think these cars used 2 prong plugs from the factory and don’t think 4 prong plugs will hurt as long as they are not extended tip and that plug does not look like extended tip.
    Oct 2003
    Seattle
    99 M3
    As I recall the factory Bosch plug was a copper core four electrode plug.
    UT
    98 M3/4/5
    single prong coppers are much better than any of this platinum irridium plutonium 85 prong crap..
    98 Estoril ///M3 4/6
    S54 swap CSL
    Jun 2008
    Surf City, NC
    1995 Dakar M3
    Quote Originally Posted by TH3 Shifty View Post
    This
    Mar 2013
    Texas
    98' Hellrot M3
    Update! So finally got a chance to get a endoscope cam in cylinder 6, looks good piston and cy. walls look undamaged. Tried turning the engine over by hand but everytime cy.6 got to TDC it would lock up, ended up using a mirror adapter on the endoscope cam to see if maybe a valve had fallen out and to my amazement found a chunk of metal that got banged into
    the cylinder head
    Screenshot from 2017-11-22 01-57-00.pngScreenshot from 2017-11-22 01-57-17.png
    so when the piston is at TDC that metallic piece is preventing the piston from going up and jamming up between the head and piston head still have no idea what happened or what caused that to happen. I'll be pulling the engine and taking the cy. head and oil pan off to inspect the rods, replace the leaky oil pan gasket and hopefully the head is salvageable but from the looks of it, it might not be I'll keep this thread updated with results and pics of the process.
    Mar 2013
    Texas
    98' Hellrot M3
    AlpineM3OldAsMe - Yes those are quad electrode plugs the PO was running, as of now only cy.6 plug got damaged
    Twright - I checked the part # on the plug and yep Its OEM plug
    RRSperry - Coulnd't do a comp test as the piston is locking up so pulling the head off this weekend
    pbonsalb - yep sure does look like something got in there, waiting to see what the metal piece is once I get the head off
    bluptgm3 - that is correct, based in the part# on the plug
    Jun 2005
    New England
    Member butters stoch had a similar issue. Found a screw smashed into the chamber. He pulled the head, removed the screw, polished the chamber a bit and reused the head.
    Mar 2006
    Edmonton,CANADA
    1997 BMW M3 Coupe
    In for the results!
    Mar 2013
    Texas
    98' Hellrot M3
    So finally got a chance to take apart the engine in my friends e36, and boy were we surprised by the findings , Looks like cy.6 took a beating for who knows how long and the cylinder head is eaten up and possibly melted too, apart from that we found a chunk of metal about 2mm x 4mm in cy.6 which would explain the bent intake valves on that cylinder. Still have no idea what could have caused this catastrophic failure, car was running fine, idle was perfect no vanos rattle or knocking. Just all of a sudden some rough idle followed by knocking as the car coasted to the side of the road . Still puzzled on what may have caused all this, to me it seems someone tried to rebuild the engine at one point and did shoddy work because cam cap 7 on the intake side was flipped around facing driver side and every other cam cap was facing pass side caps showed marring on them too, also the head gasket that was used was a victor reinz and did have burn marks between the cylinders and I have heard of these specific VR gaskets failing so thats another thing to consider. Engine is too far gone to rebuild, it would need a new head and a rebore along with new pistons which would take even more material out of the s52's thin walls. I gave some options to my buddy about what to do from here and he's decided to do a base m52 turbo build so currently looking for a donor car, another s52 laid to rest
    Screenshot from 2017-11-29 01-08-48.pngScreenshot from 2017-11-29 01-09-20.pngScreenshot from 2017-11-29 01-09-38.pngScreenshot from 2017-11-29 01-09-58.pngScreenshot from 2017-11-29 01-10-17.png
    UT
    98 M3/4/5
    why would it need an over bore? are the cylinder walls scored? the head is &%$# yes and the piston.
    S54 swap CSL
    Jun 2005
    New England
    I doubt anyone tried to rebuild the motor. More likely a very amateur mechanic head gasket change. He probably is responsible for the foreign object -- maybe something fell into the intake manifold.
    I have read of people swapping in a used piston with new rings. I probably would not do it unless I was on a very tight budget and had lots of free time to do t he job over again if necessary.
    There is a $1200 low mileage S52 with thicker HG already installed for a turbo project for sale now in the classifieds. Looks like a very fair deal to me. But an M50 or M52 is also a great budget motor since they are about $500 used. The lower displacement does not spool a turbo as well, but sometimes your budget does not allow all of the best parts (like an S52 instead of an M52).
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    You do know people are making 800+ whp on 87mm s52s. Bore and hone this s52 and put 86.5mm or 87mm pistons in it if you are going turbo. S52 is a much, much better engine for boost. Look at some dyno graphs of m5x vs an s52 with similar set up. Power band and torque curve along with over all torque is much better in the s52.
    I have an 86.5mm S52 and am making north of 600whp currently. Unless you want 1000whp I wouldn't even consider wall thickness...
    Mar 2013
    Texas
    98' Hellrot M3
    My friend found a wrecked donor car for dirt cheap and has a m52 and ZF in it
    he's picking it up this weekend and were gonna swap it into his current e36,
    possibly swapping the s52 cams into the replacement m52 for the extra hp
    TH3 Shifty - Yep cylinder 6 has some pretty deep scoring
    pbonsalb - Yea, most likely a headgasket job gone wrong.
    My friend did consider buying a used s52 piston, doing some slight
    honing with the ball hone tool and throwing it in but the cylinder
    wall is pretty scored and would have to bore all the cylinders and
    use new pistons $$$$
    rajicase - yea that's true I have seen a couple boosted s52 builds, just easier
    to source a m52 if things go wrong .
  1. Replies: 8
    Last Post: 02-19-2008, 01:01 AM
  2. performance chip/spark plug problem possible?
    By jraifaisen in forum 1992 - 1999 M3 (E36)
    Last Post: 12-04-2007, 11:32 PM
  3. Replaced Spark Plugs, now throwing code 1226 (knock sensor)??
    By Matt at Dunlop in forum 1991 - 1999 (E36)
    Last Post: 06-04-2007, 05:49 PM
  4. part number for spark plugs s52 engine.
    By billyr3d in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 05-22-2007, 11:29 AM
  5. Spark plugs for S52?
    By sab0276 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-21-2003, 12:48 PM
