Results 1 to 6 of 6
Thread: Roasdster rear window trim link
    Jul 2017
    Miami
    1997 Z3 2.8 convertible
    Help, not too long ago there was a link with instructions to replace the rear window trim with 1/4 inch rubber hose using RTV and now I cannot find it
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    BMW MOA 696, BMW CCA 1405
    Jul 2012
    Henderson, CO
    2000 M Roadster
    I did this about 3 to 4 years ago and now I am finally replacing the window with an ADM. Getting the RTV off the fabric around the window has been a chore. In retrospect, I should have just bought a new window back then. Just some food for thought.
    Oct 2012
    Louisville, KY
    Quote Originally Posted by Pat Gautier View Post
    I did this about 3 to 4 years ago and now I am finally replacing the window... In retrospect, I should have just bought a new window back then... .
    Did you replace the window because the rubber tubing trim fix started to come off after 3-4 years?
    Not only would the RTV make the canvas too thick to go into the new window's trim, but it might extend beyond what the new narrow trim can cover.
    So after doing the rubber tube and RTV fix, the next window would be easier if it were an Emiata with the wide canvas trim.
    Kent, Ohio
    1998 M Roadster
    This.
    Jul 2012
    Henderson, CO
    2000 M Roadster
    I had to replace it because the window cracked. The tubing held up OK, just pulled away a bit at the upper corners. An Emiata top would hide the RTV but I HATE the look of the canvas trim on those. The ADM is an excellent solution and even with some of the remaining RTV visible I like it better than I would the Emiata.
  1. Rear Window Trim Corners
    By cshorett in forum 1991 - 1999 (E36)
    Last Post: 10-31-2006, 03:09 PM
  2. How do you remove front and rear window trim.
    By fixture in forum 1991 - 1999 (E36)
    Last Post: 09-29-2006, 08:24 AM
  3. WTB: ps side rear window trim (black)
    By X2theZ3 in forum 1987 - 1991 M3 (E30)
    Last Post: 01-04-2006, 07:12 PM
  4. Where Can I Find New Rear Window Trim?
    By valkyrie98 in forum 1991 - 1999 (E36)
    Last Post: 09-27-2005, 03:51 PM
  5. How to remove rear window trim 325is E36
    By ponq in forum BMW Rides & Events
    Last Post: 04-11-2003, 10:32 AM
