Results 1 to 8 of 8
Thread: Front lower control bushing replacement cost
    Sep 2017
    Port Charlotte FL
    04 325ci, 92 Acura NSX
    I was told that the front lower control arm rearward bushings are loose on my 325ci. The shops estimate was $100 parts and $320 for labor for both sides. What is a typical labor cost to replace them? Also what does a wheel alignment usually cost on these cars?
    Thanks for any insight you can give me.
    Mar 2016
    Portland, OR
    2002 325Ci Cabriolet
    Find another shop.
    Parts are not that expensive and this is a DIY job with marginal skills. Even easier if you have a lift available. A total of four bolts hold the CAB's in place and you can access them all after removing the protection plate. I did this job in under an hour with a lift. Paid less than $40 for the parts (New Bushing with Carrier) and have enjoyed the last 2400 miles of driving with no steering wheel shake while braking.
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    I can get alignments done here in Germany for 80 bucks at a tire shop and about 125 at a dealership.
    Those bushing take exactly 1 hour to replace, and you really don't need any special tools to do so, just a bit of elbow grease to push them back on. But if you do it yourself, I like this set of tools. Then if you have to do it again, you have the tools.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Oct 2005
    San Francisco, CA, USA
    '94 318ic, '00 323it
    Alignment costs for all 4 corners range from $100 with a 6 month guarantee at Sears to $250 at the dealership.
    Alpine 318ic FTMFW!
    Sep 2017
    Port Charlotte FL
    Thanks for the info guys, after looking at the parts for sale online, I was wondering why the labor would be so much. I'll be ordering the parts online and getting someone else to put them on. I guess I'll steer clear of that shop in the future. Thanks again; Howard
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    Already pressed in:
    https://www.fcpeuro.com/products/bmw...6-31126757623l
    https://www.fcpeuro.com/products/bmw...-31126757623my
    Find a local bmw nut and throw him a 6 pack or 2 for the job.
    May 2015
    United States
    2004 BMW 325i
    I followed this video when I changed both control arms, very easy to you yourself. https://www.youtube.com/watch?v=5cZ5...SOoJg&index=10
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Quote Originally Posted by nuby View Post
    The mech isn’t very good. An easy way to remove the bushing is to remove the 2 bolts that hold the bushing carrier to the chassis. Then, place a large open end wrench (I have a 36mm) on the shaft in front of the bushing. Hit the wench with a mallet or large hammer. Typically takes 2 or 3 whacks to get the bushing and bracket off.
    the metal plate the mech removed is not a skid plate. It’s a chassis re-enforcement panel. It’s a critical component of the chassis. The 16mm bolts ARE SINGLE USE BOLTS. That is, they must be replaced with new bolts when reinstalling the plate. Why? The bolts, when torqued and turned, are stretched. They do not return to their “new” dimensions. Yes, they are expensive (~$3 each), but reusing then can compromise the chassis.
  1. Front Lower Control Arm Replacement Tips
    By Michael-Dallas in forum 1992 - 1999 M3 (E36)
    Last Post: 10-01-2009, 09:26 AM
  2. How-to on Front Lower Control Arm Bushings???
    By UNVMYM3 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-12-2009, 08:02 AM
  3. Front Lower Control Arms | Bushing Replacement
    By beamer4lyf in forum 1991 - 1999 (E36)
    Last Post: 11-15-2007, 03:57 PM
  4. Front lower control arm bushings
    By M3RACER in forum 1992 - 1999 M3 (E36)
    Last Post: 05-24-2007, 09:06 PM
  5. FS: 96+ M3 front lower control arm bushings
    By LEVOC///MPower in forum BMW Parts For Sale
    Last Post: 04-27-2006, 01:02 PM
