Results 1 to 9 of 9
Thread: I should know this -- but i dont... wheel angles ?
    Jan 2017
    orlando,fl
    2000 2.3l z3
    When I look at my z3 from the rear--- I see the rear wheels aernt "square" with the concrete.
    Tonight I laid a carpenters square on the concrete and slid it up to the tire side wall. At the top I see about 1 inch gap when the square
    touches the sidewall at 6 O-Clock. Both sides same.
    Moved the square to the front wheels--- get about a 3/8 on front wheels......
    Is this "normal" or am I way out of adjustment ??????
    (I have new tires so I dont want to to be out of adjustment for very long)
    Tim
    Jul 2004
    Houston, TX
    36 Cylinders
    Sounds about normal for non-M.
    The rears on non-M are somewhere 2-3 degrees of negative camber.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Apr 2016
    Philadelphia
    1997 m3
    When was the last time you had a wheel alignment performed?
    To help prolong the life of your new tires, id recommend getting an alignment performed by a BMW focused shop. Ive seen regular alignment shop butcher alignments pretty bad.
    You cant really judge your alignment with the naked eye, you can get it in the ballpark, but the fine tuning needs to be done on a rack.
    Denver, Colorado
    MRster / Z4 M4i / X5 M50
    An alignment shop can only adjust the front toe on our cars (if it is stock). What is being discussed here is the rear camber. Lowering the car can increase the camber. I'm not sure what the stock setting is. What a BMW alignment shop can do is tell you how much (if any) the toe, camber and caster is and what it should be, but the toe is the only thing they can adjust. After market add-ons can address front camber and caster and rear toe.
    2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels. Looking for a new home.
    2022 Z4 M40i, Misano Blue Metallic, Prem Pkg, Driver Assistance Pkg
    2023 X5 M50, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg.
    Oct 2003
    Seattle
    99 M3
    I heard once
    “If a car goes off the road tail first, it is a design flaw. If the same car goes off the road nose first it is driver error.”
    More camber in the rear than in the front increases the likely hood of understeer.
    Apr 2016
    Philadelphia
    1997 m3
    Quote Originally Posted by khammack View Post
    Ah you are indeed correct. slipped my mind totally. Working on cars for a living makes you crazy sometimes . Id still recommend op get an alignment with the new tires. That is of course if he hasn't had one done already.
    Feb 2012
    MN
    1997 z3 roadster
    More importantly it will create toe out which will cause the inside of the tires to wear excessively. While it can't be aligned without modifications, an alignment shop can give you the readings so you know if you are in spec or not.
    It's a Hybrid--Burns Gas and Rubber
    Dec 2014
    San Francisco, CA
    2001 Z3 3.0 Coupe
    Quote Originally Posted by fairchild View Post
    Tim
    Just to give you a bit more info....this video gives some good images about what camber, toe, and caster are. Camber starts at 1:29, and toe starts at 2:20:
    2001 Z3 3.0 Coupe--Sterling Gray/Sunroof Delete/5MT
    Jul 2004
    Houston, TX
    36 Cylinders
    2000 Z3 2.3 Alignment.
    -Abel
  1. I should know this, but
    By daven in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 05-10-2012, 06:50 PM
  2. If you own an E46...you probably should know this
    By pureco99 in forum 1999 - 2006 (E46)
    Last Post: 12-04-2008, 05:22 PM
  3. I should know this...
    By moroza in forum 1988 - 1996 (E34)
    Last Post: 06-17-2007, 11:10 PM
  4. Business CD: I'm sure everybody knows this but...
    By DaveCM3 in forum 2001 - 2006 M3 (E46)
    Last Post: 01-26-2007, 04:15 PM
  5. Everyone should know this
    By ehrhart in forum 1975 - 1983 (E21)
    Last Post: 03-15-2006, 07:05 PM
