RM European Auto Parts
Results 1 to 3 of 3
Thread: transfer case oil leak?
    Nov 2017
    San Antonio, TX
    2010 BMW X3
    i have a 2010 x3 with 116,000 miles, i noticed something leaking from under front passenger side. substance was oily and somewhat clear. next day the abs,4x4,and some other lights turn on!!! the lights went away but its makes a weird sound when i accelerate...dont know what it is please help.
    Pelican Parts's Avatar
    Pelican Parts is offline Senior Member Supporting Vendor
    Aug 2013
    Harbor City, CA
    '02 E39 Touring
    Hello and welcome to the forum! Did the check engine light come on as well? I would recommend pulling the codes to see what comes up - this will give you a good place to start troubleshooting.
    888.280.7799 | 6am - 5pm PST
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Welcome to the forum, Kate.
    It's unlikely that the fluid and the warning lights are related. However, you need to take the warnings very seriously. In order to know what the problem is, the car needs to be connected to a BMW specific diagnostic computer. If you don't already have a good BMW specialist shop that you like....now is the time.
    At 8 years old, and 116k miles, the car likely needs some serious maintenance and repairs, if it hasn't been faithfully maintained by a BMW tech.
    I'd recommend that you make an appointment for a full inspection of your car, including a scan of all the computers, and a list of what work it needs.
    Several different computers can make those lights trigger, and there are probably a hundred different inputs to those computers, and several hundreds of different issues which might be the cause. You need to know which it is, and you need to know what else might be getting ready to give trouble.
    Certainly, you can buy a very good BMW scan tool, for ~$200, from ECS Tuning. To save another $50, you can buy the same tool from EBay and the like....but you lose the support built in to the ECS transaction.
    This forum will be happy to assist you in understanding the codes from your computers . Have the shop print you a sheet, with the code descriptions, in actual words (not just numbers - good computers speak English.)
    With modern BMW's it's quite important to have someone experienced look the car over, on a regular basis.
    You know that your transfer case, transmission, and differentials need oil changes, too, I hope? Brake fluid? Coolant?
    All the best,
    Chris Powell
    BMWCCA 274412
  1. Help identify this Oil leak on intake & Transfer case
    By mitul333 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 03-31-2015, 04:32 PM
  2. Crank Case Oil Leak on a 2009 X3
    By Petervt in forum 2003+ X3, X4 (E83, F25, F26, F97, F98, G02)
    Last Post: 12-26-2014, 12:11 PM
  3. transfer case oil
    By khalegh in forum 2004-2010 (E60,E61)
    Last Post: 08-16-2010, 03:45 PM
  4. Oil leak between head gasket/timing case
    By ztan in forum 1991 - 1999 (E36)
    Last Post: 05-31-2005, 06:23 AM
  5. norcal: going rate for changing tranny&rear transfer case oil?
    By comptechgsr in forum California sponsored by Avus Autosport
    Last Post: 06-10-2004, 07:49 PM
