1996 E36 Hellrot M3 LS1 390 WHP Conversion
I've owned this car for 2 years and developed it into a reliable and streetable track car. The car made at 390 wheel horse power on Horse Power solutions dyno(~450 at the crank). This is a fast and loud car, and considerably faster than an e46 m3.
Car does have AC and heat.
PICS Here:
https://norfolk.craigslist.org/cto/d...389085243.html
These things have been modified or replaced with OEM:
Engine-
1999 LS1- Stock Long Block
*FlowTech Induction Cam Kit
*Streetsweeper HT Cam 228/232 111 .612 .600
*.650 Lift Dual Valve Springs
*7 Degree Chromoley Retainers
*Hardened Seven Degree Valve Locks
*Steel Shelled Viton Valve Seals
*FTI Pro Series Hardened Push Rods
*ARP Crank Bolt
*Improved Racing Oil Pan Baffle
*New GM Oil Pan Gasket
*LS2 Timing Chain
*Trick Flow Timing Chain Dampener
*Melling HV 10296 Oil Pump
*New Timing Cover Gasket & Seal
*New Rear Main Seal
*Tuned by Horsepower Solutions in Newport News
*LS6 Intake Manifold
*LS6 Rear Coolant Block Off Kit
*LS6 Valley Cover & Gasket
*O2 Sensors
*Stock Ported Throttle Body
Custom 3.5" Intake w/ K&N Filter
Katech Tensioner
Turn One Power Steering Pump
OEM Water Pump
OEM Truck Alternator
PowerMAX Starter
Vorshlag Ceramic Coated Headers
Vorshlag Engine Mounts
Vorshlag ABS Relocation Bracket
Corvette Fuel Rail Covers
Custom 3" Buschur Racing Exhaust
NGK TR55 Plugs
MSD Wires
Spal 16" Low Profile Fan
Modified Speartech Standalone Engine Harness
Lokar Throttle Cable
Lokar Throttle Cable Bracket
Summit Racing Coolant Catch Can
Stant Radiator Cap
Norris Oil Catch Can
Cooling-
Huge custom made radiator by VA Rod
Custom made expansion tank by VA Rod
Drivetrain-
Brand New T56 Magnum Transmission
Mcleod Magforce twin disk clutch with racing flywheel $1500
New GM Slave Cylinder
ARP Clutch & Pressure Plate Bolts
Custom Made short shifter for correct location $600
Vorshlag Clutch Line & Remote Bleeder
Vorshlag LS1 Transmission Mount With poly Bushing
Metal Master cylinder with custom line
Drive Shaft Shop 3" Custom Chromoly Drive Shaft w/ 6 Bolt CV Joint
Jim Blanton E32 210mm Differential w/ E60 M5 3.62 Ring & Pinion & GKN 7 Disk LSD
Rally Road 210 Diff Conversion Kit
Subframe Differential Mount Reinforcement
HVAC
All functions with stock bmw control
New compressor
Custom made ac lines by Piertek
Interior-
Euro Steering Wheel
Euro Gauge cluster with working oil temperature gauge
Reupholstered Headliner(black alcantara)
Brake Switch
OEM Accelerator Pedal w/ OEM Bushings
OEM Shift Boot
OEM E-Brake Handle & Boot
Exterior-
The suspension points have been reinforced to handle the extra power
Motion Motorsports Underpanel w/ Radiator Baffle
Carbon fiber brake ducts
OEM Kidney Grills
OEM Roof Ledge Molding Right & Left
OEM Outer Window Weather Striping
OEM Rear Window Weather Striping
OEM Door Handle Weather Striping
35% Window Tint
Suspension-
OEM Tie Rods
OEM Front Sway Bar End Links
OEM Rear Sway Bar End Links
OEM Rear Ball Joints
OEM Front Lower Control Arms
Rear Wheel Bearings
Fuel-
Walbro 255 In Tank Pump w/ Custom 10 Gauge Hot Wire Kit
WIX Corvette FPR
Russell -6an Braided Fuel Line & Fittings- FPR to Fuel Rail
DEI Fuel Line Fire Sleeve
Wheels & Tires-
Choice of
*Kosei K8R with continental street tires (255/40/17)
*Kosei K1 with new hankook rcomp track tires (255/40/17
Vorshlag 75mm Stud Kit w/ Lug nutsECS 10mm Front Spacers
Options:
I WILL NOT SELL ANY OF THESE PARTS UNTIL THE CAR IS SOLD!
+1500 Track Suspension
Vorshlag AST 4100 Coilovers
Hyperco 550 Front Springs
Hyperco 650 Rear Springs
Vorshlag Camber/Caster Plates
AST Rear Spherical Shock Mounts
Rear Shock Mount Reinforcements
AKG Spherical RTAB's
AKG RTAB Pocket Reinforcements
AKG Rear Sway Bar Reinforcement Kit
AKG Rear Adjustable Lower Control Arms
AKG Front Control Arm 75D Bushings
AKG 75D Subframe Bushings
Vorshlag 10.9 Lower Shock Bolts
+1500 Track Brakes
Front and rear 4 piston Brembo BBK
Large selection of street and brake pads(probably 2k+ just in pads)
+1200 Recaro Seats
Genuine Recaro seats with custom made brackets.
Seat sliders
+700 4 Point Roll Bar
Auto power roll bar professionally paint HellRot red
2 4 point harness's
pics, phone number, price?
Price and Pictures, please!
WUTCONE?
