Results 1 to 22 of 22
Thread: replacing Alternator's voltage regulator
    Jan 2006
    BC Canada
    2000 BMW 323i, 2012 Merc
    Question replacing Alternator's voltage regulator
    For a week my 2000 323i was not driven and the battery got drained out completely.
    I jump started the car and drove for an hour. Then parked for few hours and the battery got drained out.
    Jump start it again. Drove for an hour and parked at home. Next morning same scenario, battery depleted.
    Got my battery charger and charged the battery over the night with "deep-cycle 2Amp mode". The battery is fully charged now and holds 12.1 Volts.
    I suspected that the alternator doesn't charge the battery.
    I tested the alternator and it shows 13.5 Volts. I think that the alternator should be over 14 Volts.
    I am guessing the brushes in the voltage regulator are worn out and it's the time to replace it.
    The question is - has anyone replaced the voltage regulator without removing the alternator out of the car?
    I saw on YouTube someone did this on a Volvo. I wonder if the same can be done on E46 ?
    Dec 2012
    North Carolina
    2009 335i M-Sport Coupe
    You have a dead battery. If you are showing 13.5volts with the car running, the alternator is working fine. A fully charged battery should show at least 12.7 volts. Load test the battery.
    Apr 2009
    Vancouver Isl, BC, Canada
    98 Euro M3, 04 M3, 06 M5
    +1 on Battery. 13.5v is exactly what you want in these cars. The voltage regulator doesnt let these get much higher due to all the electronics.
    12.1v isnt very high for a "fresh off the charger" battery. Every battery has a bit of surface charge after charging, you need to place a load on the battery briefly before you can get a stable voltage reading. Turning your key on without starting the engine for a minute or 2 is usually enough.
    Current:
    - 09 335i MSport, FBO.
    - 98 Euro M3, Estoril Blue
    - 04 M3, Carbon Black, 6 Speed Coupe
    - 06 M5, Black on Black, Full Leather.
    - 73 3.0CS, Tagia Green, 5 speed M30b35 converted
    Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
    Jan 2006
    BC Canada
    Update:
    Today the battery test shows 11.5 Volts and the alternator test shows around 12.5 -12.7 Volts.
    I ran the test 2 times.
    When I tried to run the test for the 3rd time the battery Voltage showed up, but then when I've tried to start the car in order to test the alternator the engine couldn't start anymore.
    I turned the car completely Off and started the vehicle OK.
    Then tried for the 4th time to run the alternator test and the same scenario, the car doesn't want to start.
    Doesn't this means that the alternator is bad ?
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Start with replacing the battery first, then worry about the alternator second.
    I had a dead cell in my winter beaters battery, was able to jump it off and drive it home, however everything was acting funky.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Jan 2006
    BC Canada
    I drove to the battery shop. They tested , all is OK with the battery. They checked the alternator with their tester, and it shows that the alternator output is 12.5 Volts.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    That’s low. BMW sourced alternators frpm Bosch and from Valeo. They are not interchangeable. The first step is to determine which alternator is in the car. Remove the air filter box and the upper intake hose. Use a flashlight and a mirror to read the label on the crack of the alternator. Tre label will tell you the manufacturer and the capacity in amps. Replacing the voltage regulator in a Bosch alternator is fairly easy once you’ve removed it from the car. Basically, you remove a couple of screws at the back (make sure you use a quality screwdriver as the screws are in there tight). Then remove the crap that’s accumulated in the alternator. The voltage regulator is held in place with 2 screws (maybe small bolts). Swap the regulator and put it back together.
    Dec 2016
    Cupertino, CA
    2001 BMW 325i
    I've had alternators intermittently go bad (low idle and high heat) causing charging issues and rough idle issues when car was running. At high RPMs it would read 13.5v, but at low RPMs it would bounce between 13.5 and 12v. If your alternator output is 12.5v, then it is probably bad. I've never just changes the VR.
    If you replace the alternator, you can use either Valeo or Bosch, but if your new alternator doesn't come with a pully, you'll have to replace it with the same one that's already in your car, as the pullys are a different size between the two brands.
    dworthy's Avatar
    Nov 2010
    Quote Originally Posted by abrittis View Post
    Please note what Marc said above about non-interchange alternators.
    Darin
    Current:
    Past:
    M-Flight Member
    Apr 2009
    did you do something in between like charge up the battery?
    How is your engine ground cable? this is starting to sound like a bad connection issue.
    Also a battery at 11.5v with no load on it is dead.
    Current:
    Los Gatos CA
    1987 325is, e34, Z3, e39
    It's possible that your alternator has a bad diode, but that's an uncommon spontaneous failure with modern alternators. Generally that only happens when the battery is connected in reverse.
    At this age, it's much more common that the brushes are worn down and barely making contact.
    To verify it's easiest to remove the alternator. Perhaps someone that does this task daily can remove the regulator by feel and inspect with a mirror, but you won't be able to. A Bosch alternator has a plastic back cover held in place by two terminal nuts, and perhaps a screw. Once removed, clean out the accumulated leaf bits and litter to reveal the regulator/brush assembly. This is held in place by two screws, usually with #2 Pozi-Drive heads. Do *not* use a regular #2 bit on these, as it will cam out and round the screw head.
    I'm uncertain of the modern specs, but older Bosch alternators had new brushes that extended 13mm, and 5mm was the wear limit. Much like brake pads, there needs to be plenty of material to provide thermal insulation from the hot contact surface.
    When reassembling, tighten the fasteners only to snug or carefully follow the factory torque specs. The terminal nuts are soft plated copper and can't handle the torque that their size suggests.
    Jan 2006
    BC Canada
    I finally received my borescope and used it to see the alternator's label without removing the filter box. I have Bosh 0123515022.
    Now I know which type of voltage regulator is required. https://www.ebay.ca/itm/REGULATOR-fo...53.m1438.l2649
    My original question: is there possibility to replace the voltage regulator without taking the alternator out of the car?
    Also , has anyone tried to replace just the brushes ? I wonder if these brushes are suitable ? https://www.ebay.ca/itm/BOSCH-ALTERN...53.m1438.l2649
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Don’t buy the VR from eBay as you can get a counterfeit part. Go to fcpeuro for the part.
    Yes, you have to pull the alternator from the car to change the VR.
    Im still betting the battery is toast. Why? Lead acid batteries don’t tolerate a total discharge. The chemistry permanently damaged the lead plates, thus reducing the battery’s capacity. Plan on a new battery before next winter.
    Mar 2017
    Norwich, Connecticut.
    E46 wag. E36 convertible
    Healthy alternators with BAD batteries...........5 year batteries is often the time to replace them. Yes some live again as much time..but rarely. As batteries become older they develop resistance..gradually. An older battery 4 to 6 years, develops resistance to charging from your alternator. When this happens, your alternator begins to work harder. Alternators in our BMW cars are quite expensive to replace. In my opinion, switch-out the $150 battery for a new one in 5 years...or sooner..
    Los Gatos CA
    As batteries grow older, the internal resistance increases. That *decreases* the charge acceptance / recharge current. The alternator doesn't have to work as hard to recharge them, although it does have to work longer.
    Mar 2017
    Yes, you are correct. Alternators put out dc voltage based upon their command (via regulator) A really bad and or old battery with a most resistance will demand max from attention from the alternator...thus shortening the alternators work life.
    Los Gatos CA
    A battery with a shorted cell will result in the alternator putting out its maximum current, which could possibly shorten its life.
    An old battery without a shorted cell will result in the alternator putting out lower current, which puts less stress on it.
    But what type of failure are you worried about? The bearings? A heavy electrical load puts more mechanical stress on the whole alternator, but the bearings are significantly oversized for the load. They usually fail when the rubber seals leak, which is more dependent on heat and environmental conditions.
    The brushes? They usually fail from wear. They last a very long time if everything goes well, and only wear quickly if grit gets into their semi-sealed enclosure. The control current goes through a thick continuous copper ring, and has a trivial impact on the brush life.
    The regulator? There isn't any significant load-based wear mechanism. (Thermally driven diffusion in the semiconductors is so minor that it can be ignored.)
    The diodes? That's a tougher one to call. High current output increases the heat the semiconductor junction. Thermal diffusion could be an issue. Thermal cracking could be an issue. Diodes are really robust, but it's tough environment. It's not often that diodes fail in their regular environment, but they can fail with a shorted battery cell or a momentary reversed jump start. And they can fail in a way that a rebuilder won't catch. I wouldn't expect diode failure to happen out of the blue, but it's one of the top things to suspect in a recently installed rebuilt alternator.
    Jan 2006
    BC Canada
    Today after charging the battery for 24 hours I've tested it with the Fluke multi-meter and it showes 12.2V.
    I connected my Fluke multi-meter and pushed the min/max button in order to record the minimum and maximum reading after I would start the car (i.e. to load test the battery and to check the alternator's output). The minimum reading after the car start was 10.0V (indication for the battery load test) and the maximum reading was 12.2V (alternator test indication).
    Then I ran on-board test (holding the left button on the odometer for few seconds, then clicking till it will get me to #19 , then wait for a second, then click till it will get to #9) and it showed me following: the battery 11.7 V . I immediately checked the battery with Fluke meter and it showed 12.2V .
    I drove for about 15 minutes with the on-board tester On and
    the alternator was fluctuating between12.7V to 13.1 V.
    Looks like the battery doesn't take full charge (as I understand it should of been minimum 12.6V) , however the battery output under the load is 10V (as I understand it should be minimum 9.6V).
    Looks like the alternator's maximum output is 13.1V but my battery doesn't take more then 12.2V.
    Do I still need to change the battery or the current battery is sufficient with 10V output when loaded ?
    Jan 2006
    BC Canada
    Quote Originally Posted by MarcoZandrini View Post
    I contacted the sales rep of FCP Euro and it appears that they do not sell voltage regulators for Bosh alternator model 0123515022
    Los Gatos CA
    If you charge for a few hours and the voltage is still under 12V, you have a dead cell in the battery.
    Your 12.2V is an over-charged battery at 14.6V with only 5 of the 6 cells working.
    Apr 2009
    12.2 is super low for a fresh off the charger battery.
    The voltage regulator on these alternators is not serviceable separately.
    Current:
    Jan 2006
    BC Canada
    Legoman67, I’m confused by your statement about VR.
    In the 7th post above MarcoZandrini advised that VR for Bosh alternators is easy to replace.
  1. Alternator or Voltage regulator
    By it2castelo in forum 1996 - 2003 (E39)
    Last Post: 09-23-2007, 11:51 PM
  2. Alternator or voltage regulator problem? (with PICS)
    By edirtyfour in forum 1988 - 1996 (E34)
    Last Post: 08-23-2007, 02:37 PM
  3. Alternator or voltage regulator?
    By jpspohn in forum 1975 - 1983 (E21)
    Last Post: 03-06-2007, 12:18 PM
  4. Alternator or voltage regulator?
    By Ryan Stewart in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-01-2005, 06:25 PM
  5. technical question regarding alternator and voltage regulator
    By Blazin95Red325i in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-27-2005, 10:31 PM
