Results 1 to 22 of 22
Thread: DSS Question
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    DSS Question
    Just received a DSS driveshaft supposed to be for a ZF 5 speed and 210mm diff.
    Went to install it and have a couple questions;
    1) The cap on the end of the CV A) Has a bulge in it that doesn't allow the driveshaft to sit flush with the diff, it leaves a small gap. And B) doesn't fit inside the lip on the diff that the stock driveshaft fits in.
    2) The CV has to be almost completely extended in order for the length of the driveshaft to be correct. Is this normal..?
    Manchester, N.H.
    96 332IS 6466 turbo
    There are 2 aluminium cups that need to be bolted to the diff and the ZF. Then the shaft. So 3 pieces.
    Sent from my E6782 using Tapatalk
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
    Feb 2012
    1995 BMW M3
    Two aluminum cups? I have the aluminum adapter that bolts to the ZF and converts that flange to a 4 bolt flange.
    Manchester, N.H.
    96 332IS 6466 turbo
    There is also an aluminium adapter on the diff side. 3 pieces and a bunch of bolts.
    1996 332IS
    Built 3.2
    Feb 2012
    1995 BMW M3
    We got it figured out. The guy just forgot the diff flange adapter. All is good in the world. I was about to shoot myself, like I know how to install a driveshaft why am I having so much trouble with this... lmao. Oh well, glad we got it sorted.
    Thanks butters
    Manchester, N.H.
    96 332IS 6466 turbo
    Kool. Now go run some 10 second times.
    1996 332IS
    Built 3.2
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    Quote Originally Posted by butters stoch View Post
    kool. Now go break some more stuff.
    Sent from my e6782 using tapatalk
    ftfy
    Feb 2012
    1995 BMW M3
    The DSS Ds is effing beefy.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Let us know how it feels at 120.
    Feb 2012
    1995 BMW M3
    Will do. Its the new version which supposedly doesn't vibrate. We'll see.
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by rajicase View Post
    They are still working on that version
    milKt's Avatar
    pre-version
    Feb 2012
    1995 BMW M3
    This car has gotten so wildly impractical that I honestly don't care if it vibrates.
    Sep 2008
    Wilmington NC
    96 Oil Gobbler
    You say that now....
    Vancouver, B.C., Canada
    '97 M3
    That made me LOL!
    I have that ‘new’ one as well.
    Feb 2012
    1995 BMW M3
    Quote Originally Posted by GT35Rm3 View Post
    LOL
    I'm about one more ridiculous mod away from gutting the freaking car and saying fuck it. Pure race car.
    Jun 2005
    New England
    I think I have had 3 of those new versions. They all added significant nvh over 100. But I have read of a few people say theirs were fine.
    Feb 2012
    1995 BMW M3
    Damn you gone through 3 DSS driveshafts.
    Jun 2005
    New England
    None broke. Changed for other reasons — first was for 188mm, 2nd was for 210mm and 3rd was foam filled for 210mm to reduce the singing sound at 55-75 on the highway that you may hear if you have a quiet exhaust.
    '97 M3
    I installed a louder muffler on my car to cover up some of the noise from the driveshaft.
    milKt's Avatar
    '97 M3
    I already had the louder muffler as it is what I use for track days. It produces a lower reading on the dB meter at the track than my quiet muffler.
  1. Battery Question.
    By dbruce in forum 1991 - 1999 (E36)
    Last Post: 08-08-2011, 03:35 PM
  2. Qucik Question
    By mpbmw318is in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-01-2001, 12:55 AM
  3. Service tips question
    By MMMike in forum 1992 - 1999 M3 (E36)
    Last Post: 02-27-2001, 07:06 PM
  4. Battey Question
    By dbruce in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 02-27-2001, 04:53 PM
  5. O2 Sensor Questions
    By ///MCubed in forum 1992 - 1999 M3 (E36)
    Last Post: 02-27-2001, 02:08 AM
