Page 2 of 2 FirstFirst 12
Results 26 to 40 of 40
Thread: I Feel Like I Have 'Turned The Corner'!
  1. #26
    Dec 2013
    San Antonio
    850,76 2002 &530,84 633
    Timm, I locked and then unlocked driver's door, climbed into car, (sitting on milk crate until i get seat gear). Alarm did not sound and LED alarm light went off right away with key in 1st position. Engine spins over, fuel level indicator works, idiot lights are on, but engine did not fire. But, I did not close trunk or hood so I dont know if that affected immobilization feature.
    Will try again tomorrow and if necessary, I will get a neighbor to come over and watch for spark.
  2. #27
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    The car should start with the lids open - so you are in the realm of a million possibilities, and checking for a spark is a good place to start!
    My BMW Repair YouTube Channel
  3. #28
    Dec 2013
    San Antonio
    I finally got the engine running today for the first time since buying the car! Scott was a big help directing me to the 80 amp fusible links where I found one of them broken!
  4. #29
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Quote Originally Posted by JDP530 View Post
    SUPER job! I love that!
  5. #30
    Nov 2013
    Whitney, TX
    97 850CI
    It is awesome that you have "turned the corner", the good news is that the road of 8 ownership is very windy indeed. But well worth it.
    Desecrator of all things Sacred
  6. #31
    Dec 2013
    San Antonio
    Quote Originally Posted by 72tpik5 View Post
    Thanks!
    I put just about 100,000 miles on BMW motorcycles back in the day when I was younger riding around a lot of the country. Western states were my favorite with trips to California and several to Colorado.
  7. #32
    Dec 2013
    San Antonio
    My son asked me for an exhaust note recording, lol, so I sent him the following. He could not believe how quiet it is. BTW, I was able to use the inexpensive pressure regulators on my early model car. I bought them from Rockauto, Intermotor brand by Standard Motor Products, #PR169. They did not fit as well as the oem regulators because the external flange is thinner so the clamps would not tighten them down enough, but the orings and rest of assembly seen to fit into rails deep correctly. So I made a couple of large nylon washers and slipped them over the outside of regulators so washers sit on top of flage so clamps would hold them firmly in place.
  8. #33
    Dec 2013
    San Antonio
    I installed MID today that I had sent to California ten days ago for repair. And the radio security code for the Pioneer radio also worked. So I pulled car out of garage and was running it while I messed with radio settings. Well, a short time later steam was rising from under the hood. One of the hose fittings on the water valve/pump broke off. Guess I am lucky I wasn't on the road but I am still working on the seat. And that valve is sure expensive.
  9. #34
    Dec 2013
    San Antonio
    Last night I finished seat repair with the brass cast gear I had made locally. A machinist squared up the gear when he reamed it and then he was able to press it onto spline shaft with a tight fit that did not require a pin or set screw. So I finally got to drive my car today for the very first time since buying it! I was just cruising around the neighborhood to be sure brakes worked and to check water temp. Trans shifted well so I will do a fluid/filter change soon.
    I was very impressed with the car even at low speeds! Car feels more nimble that I expected. And, the EDC shocks seemed to be working properly. I was quite surprised how much body roll was reduced on 'sport' setting.
    Car should pass inspection tomorrow so I can get it registered and start driving it. Plenty of additional work to do but it will be nice to drive it while I continue working on other stuff. I guess headliner will be my next project.
  10. #35
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Excellent, that's great news!
  11. #36
    Dec 2013
    San Antonio
    I had a strange occurrence today since putting my car back on the road yesterday. I have driven it about 3 or 4 hours now and today I was cruising along the expressway at 60mph and I pressed gas pedal just hard enough for trans to drop down one gear and begin accelerating up to 80mph when the engine quit! I was able to maneuver across a few lanes and pull over onto shoulder of road. I turned off key and then turned it back on and engine started right up! I pulled back onto expressway and continued on my way. I have no clue what caused engine to quit.
    I tried to get the car to repeat same occurrence but it didn't happen. I also made a few hard acceleration runs from a dead stop up to about 70 and engine revs to redline without a miss. So its quite puzzling as to way it quit at highway speed under acceleration.
    I have also noticed the front of car bouncing too much traveling at highway speeds so EDC struts/shocks must not be working properly. So I will probably put a set of Bilsteins on it put I need to look at M or CSi springs or the Eibachs with a modified rear set.
  12. #37
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Check the ohm resistance on both crankshaft sensors, between pin 1 and 2 should be around .500 ohm +/- 10%.
    You can have the EDC shocks rebuilt in Poland. If you want bilsteins I have a very lightly used set available.
  13. #38
    Dec 2013
    San Antonio
    Quote Originally Posted by dragon850 View Post
    Thanks! I will check the crank sensors in the next day or two, but I did install new BMW sensors before I ever started the engine. Just hope I dont have a faulty or broken wire in the harness on top of the engine.
    I did see where Nagengast does the shock repairs.
  14. #39
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    More likely to be the fuseible links - they are well known for intermittent problems!
  15. #40
    Dec 2013
    San Antonio
    Thanks! I did replace the 80amp link per Scott's recommendation and engine started right up! Finally got to put on the road a few days ago and I have only had the one odd occurrence. I will go back and change the other fuse.
  1. Feels like I have a brand new car, and a question
    By Antrieb in forum 1988 - 1996 (E34)
    Last Post: 12-10-2006, 10:24 AM
  2. Don't feel like being flamed in the other forums, ? about Dove Grey
    By B17A in forum Georgia sponsored by Harrison Motorsports
    Last Post: 04-07-2004, 08:41 AM
  3. Car feels like its drifting...floating on corners
    By freeze in forum 1991 - 1999 (E36)
    Last Post: 12-03-2003, 01:04 AM
