Results 1 to 19 of 19
Thread: E34 Tiny ADS Software
    Nov 2017
    Brunswick MD
    1995 540i
    I have a Tiny ADS in the mail to help diagnose my 1994/1995 540iA’s SRS light, and am looking for confirmation
    -That I will be able to communicate with the E34’s SRS system using INPA and the Tiny ADS.
    -On what version of INPA is best to use and most compatible with the Tiny ADS / 1994 / 1995 e34.
    If possible, could someone post
    -A link to a recommended guide to install the above recommended, specific version of INPA with working pictures / links.
    -Information on what operating systems it’s compatible with (Windows 98 / 2000 or XP only).
    -Any tips for an INPA noob so I don’t turn my car into a brick.
    I have an old Pentium 2 class desktop with hardware serial ports and 512 mb of ram, will that be sufficient or do I need to source something more powerful.
    Please go easy, I have searched through 20 posts and am less clear than when I started.
    Jul 2004
    Houston, TX
    36 Cylinders
    http://www.bimmerforums.com/forum/sh...0#post29024210
    you can try this pack and those brief instructions for installation and setup.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Nov 2017
    Brunswick MD
    1995 540i
    Is this no longer true? That package has 7.3.0
    Jul 2004
    Houston, TX
    36 Cylinders
    Look closely, I linked post #170 which has very different software linked.
    -Abel
    Nov 2017
    Brunswick MD
    1995 540i
    Tapatalk ruins the direct link. That looks perfect, thank you very much!
    Dec 2007
    Queensland, Australia
    E70 3.0sd E21 323i
    E34’s are pre-EWS, so INPA will not provide the necessary files for diagnostics - you will need to use DIS v39 or v44.
    Jul 2004
    Houston, TX
    36 Cylinders
    That airbag module is K-line, the INPA scripts *should* work.
    Same airbag module as in early OBD2 e36.
    -Abel
    Nov 2017
    Brunswick MD
    1995 540i
    Not sure what airbag module my car has, it seems to be somewhat of an oddity and I have yet to locate the module itself (it is not under the rear seat; I have been told it is likely under the dash.) Single airbag car with build date 05/1994. It does have orange crash sensors under the hood if that helps.
    Nov 2017
    Brunswick MD
    1995 540i
    So I have the INPA 4.4.7 / EDIABAS 6.4.3 software installed (still waiting on the cable) per post 170, I think that went smoothly enough (on a clean Windows XP SP2 32bit install if that matters.)
    When the program starts, there is no E34 option. Is there a guide for us E34 guys?
    Dec 2007
    E70 3.0sd E21 323i
    Look under "Old Models".
    Nov 2017
    Brunswick MD
    1995 540i
    So... some success and some failure. Got the cable in the mail and hooked everything up. INPA gets the black dots. I can communicate with the seat memory controller and the instrument cluster (the only 2 E34 modules I found that worked), but cannot communicate with the DME 3.3 M60 / Airbag or ABS modules (IFH-0009 No Response received on all of them.)
    Any Zen advice?
    Nov 2017
    Brunswick MD
    1995 540i
    My FIFO buffers were not both at 8... possible cause? Will retry tomorrow.
    Nov 2017
    Brunswick MD
    1995 540i
    No difference at 8 and 8, same error
    Nov 2017
    Brunswick MD
    1995 540i
    Can anyone please point me to a copy of DIS v44 here or via PM? There are tons of old 4share links and guides, most of them are dead or will not let you download without an account.
    Dec 2007
    E70 3.0sd E21 323i
    Quote Originally Posted by Viper1313 View Post
    You have a PM
    Nov 2017
    Brunswick MD
    1995 540i
    Thank you David for all your help with this. DIS v44 with the Tiny ADS seems to work great on the E34 and is able to read / clear airbag codes.
    Nov 2017
    Brunswick MD
    1995 540i
    Is it possible to do a cylinder balance / smoothness test on the M60 engine with DIS v44? I have a bit of a misfire, pretty sure it is a coil or 2 (compression is fine) and would prefer to replace just a couple of coils if possible.
    Nov 2017
    Brunswick MD
    1995 540i
    The weird thing is that I can not communicate with the ECU using INPA, but DIS works fine, even though it appears to be a late model 1995 DME.
    Jun 2017
    Indonesia
    E34 530i
    Hello , sorry for bumping this thread again. I have a problem with my power windows and brake in my 530i RHD v8, I build a ADS interface from hansV and test it in INPA, black dot battery and ignition is normal but i cant get it running, i think it says ews something ( my car doesn't have ews). Power windows 4 of them is normal before i test it with DIS i downloaded from mega link. Seems like my power windws locked from General Modules. Please help
  1. Tiny ADS Interface inside 20 pin connector/software question
    By fbmbirds in forum Diagnostic Software
    Last Post: 09-27-2017, 08:03 PM
  2. Some E34 love. Adding a ski-pass sub IB
    By 12v Electronics in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 03-16-2010, 04:00 PM
  3. Most misinformed E34 CL ad I've seen
    By ross1 in forum 1988 - 1996 (E34)
    Last Post: 01-24-2010, 06:51 PM
  4. E34 M5 Stock Software?
    By 95///M3 in forum 1988 - 1996 (E34)
    Last Post: 02-23-2007, 06:16 PM
  5. E34 and Datalogging software?
    By Quick VR4 in forum 1988 - 1996 (E34)
    Last Post: 04-20-2006, 01:18 AM
