Results 1 to 17 of 17
Thread: Bluetooth?
    Jul 2010
    Irvine, CA
    1995 BMW M3
    Bluetooth?
    Hello,
    I recently acquired a 2001 740i Sport with 6 speed Manual as a second car to slowly restore it to more of a pristine level.
    Only thing I wish it had is bluetooth. I would like to use it to make phone calls and stream music only, I do not need anything displayed.
    My car came with Nav and CD changer,
    What would be the simplest and easiest way to integrate bluetooth function without hacking up the interior? (no new headunit)
    I heard you can retrofit OEM but also heard that you cannot stream music through it.
    any help would be really appreciated.
    Thank you!
    Dec 2009
    Seattle, Washington
    E23 E24 euros E34 E38
    Hi, I have a set up that might work for you. I was going to install it in my 2001 with wide screen nav but decided to go another direction. Shoot me a PM. Thanks
    Sent from my HTC6545LVW using Tapatalk
    May 2009
    Lithuania
    E38 750i FL & E36 M3 4DR
    I have GROM Audio kit installed in my E38 which came with DSP. In my other car I have Yatour kit. Both has bluetooth, A2DP streaming capability, hands free function, remote steering wheel controls, playback from USB/SD card, AUX-in etc.
    Fitting any of these units is a simple plug and play process. The choice is yours, both products will suit your needs.
    Los Angeles, CA
    2003 540i
    You can easily add bluetooth and streaming with the mentioned GROM kit or BSW Soundplicity.
    OEM like options (though expensive) would be the OEM Bluetooth kit and a Carphonics BM53 unit.
    2003 BMW 540i [Sterling Gray / Gray]
    [Msport] [Mods from A-Z] [Two-Tone Interior]
    Stuff For Sale :
    E39 OEM Technical Graphite Trim / High Polished Black & Biege / Maple wood [Click]
    E39 OEM High polished Gray Trim / Matt Chrome Interior [Click]
    E38 750iL Chrome Door sills & Roof handles [Click]
    E38 OEM 750iL Brake Caliper Upgrade kit (F+R) [Click]
    All types of E39 OEM Used HVAC Buttons[Click]
    Looking for Repaired/Reinforced E39 / E38 Rear quarter window sunshades?? PM me!
    Dec 2010
    Atlanta, GA
    E38 7er, E46 M3
    I donít really care about bluetooth calling because people canít hear you clearly from the microphone so I will install a late built BM53 module and the Miccus Minijack RX bluetooth receiver right by it. Thatíll enable the factory AUX capability on the screen and the bluetooth will take care of the handsfree music.
    GROM unit is nice, my friends use it.
    Atlanta, GA
    06 E60 M5, 07 E90 328i
    In my e38 I did a factory TCU for the phone and a GROM BT-3 for streaming.
    Oct 2007
    Bolton, MA
    2001 740iL
    I did the GROM which was pretty easy and works well enough. Not sure how great the mic is but people tell me I sound okay/fine. Minor comment, at least when I did mine last year: You can't turn off the nav screen display when on GROM. Sometimes at night I like to turn the monitor/display (I have the widescreen) off, but, GROM turns it right back on in 1-2 seconds.
    '99 328i Convertible
    '01 740iL, Stahlblau with beige interior & 18" M-Pars.
    Added 16:9 with Grom bluetooth adapter.
    Atlanta, GA
    Quote Originally Posted by jpilk99 View Post
    There is a fix for this. GROM can send you a file to download to the unit.
    Oct 2007
    Bolton, MA
    2001 740iL
    Way cool. Thanks!
    May 2003
    Willis, Texas
    '01 740i, '99 528iT
    Quote Originally Posted by wutanec View Post
    ...I heard you can retrofit OEM but also heard that you cannot stream music through it....
    True. However nothing integrates quite as nicely as an OEM Bluetooth system. My write-up:
    Like others, you could go with Grom for streaming. Why both? Because aftermarket systems require your radio to be continuously 'on' and in CD mode for any Bluetooth functionality, while an OEM system is completely independent of your radio.
    Frankie
    Texas, USA
    frankies-bmw.com
    Dec 2009
    Seattle, Washington
    Quote Originally Posted by Frankie View Post
    Frankie +1
    Dec 2009
    Seattle, Washington
    I was using Frankie's write up to assemble the parts (which I have) before I decided to follow what Franco and Chief Jimbo were doing.
    Jul 2010
    Irvine, CA
    1995 BMW M3
    I read your article regarding the bluetooth on your website. Thank you so much for the information.
    so what happens you get a call while you are listening to music through Grom?
    does it switch back to factory bluetooth when you receive a call?
    Dec 2015
    Maryland
    2000 BMW 750
    I would think you can't be connected to bluetooth to both devices at the same time, so if you're using your grom, i suppose you'd get your call through GROM.
    May 2003
    Willis, Texas
    '01 740i, '99 528iT
    Yes, it should. I don't have both in my car so I can't speak directly to how these two systems interact. But I do know all radio audio mutes during calls, although both systems will capture the incoming call (since both are paired). Therefore the Grom unit should not be audible. (In this case, use the stock mic in the headliner, not a Grom mic.)
    Keep in mind, you could opt for an aux-in for music (in place of CD changer), which may be less expensive. This avoids data loss from compression resulting in a slightly better sound.
    Frankie
    Texas, USA
    frankies-bmw.com
    Atlanta, GA
    Nothing beats the OEM TCU retrofit for hands-free telephone. I have a couple of TCU's available.
    Aug 2017
    Haverford,PA
    740iL
    Anybody know the part number of the latest TCU still fitting into an E38? There seems to be like 20 different part numbers, hard to figure. Thanks!
  1. Who has bluetooth for there cell?
    By BAVARIAN323i in forum Off-Topic
    Last Post: 06-10-2003, 12:29 AM
  2. fs: ms bluetooth wireless keyboard and mouse
    By M3corey in forum BMW Parts For Sale (Panjo) sponsored by Bavarian Auto Recycling
    Last Post: 06-08-2003, 04:19 AM
  3. Blackberry/Bluetooth PDA to Cell Phone
    By jsp98m3 in forum Off-Topic
    Last Post: 05-30-2003, 02:10 AM
  4. Bluetooth Phone Part No ... ETK help needed?
    By Kevlar in forum 2001 - 2006 M3 (E46)
    Last Post: 03-11-2003, 05:19 PM
  5. Bluetooth Technology
    By Kevlar in forum General BMW sponsored by Intercity Lines
    Last Post: 07-18-2002, 12:38 AM
