Results 1 to 25 of 35
Thread: where to find the starter bolts sizes???
    Aug 2013
    gainesville,fl.
    1977 320i
    not seeing it on realoem
    http://www.realoem.com/bmw/enUS/part...BMW-320i&mg=12
    mine vibrated out? I think just the top one, but I tried to crank it...not good. I might have mucked up the flywheel.
    Jun 2016
    Austin, TX
    1978 323i
    Feb 2009
    District Nine
    sold 78 BMW 320i
    Interesting not listed in the realoem. M8 seems too small. I'm pretty sure the top bolt is M10, the bottom is either M10, or M12. I used a 3/8" bolt for the top because the diam was a tiny smaller than the OE bolt that was being a pita to install
    Just a tiny bit of starter flex can make it sound like the ring gear(flywheel) is damaged, but it's probably fine (I'm optimistic).
    Tbd
    Nov 2007
    Sacramento, California
    1980 BMW 320i E21 M10B18
    Cool
    I measured the ones I had installed, except the starter ones , there I upgraded to larger size.
    Randy
    Feb 2009
    District Nine
    sold 78 BMW 320i
    Found the lower bolt, it's M10x75 wow, longer than I thought. I still think my upper bolt is(was) an M10. May want to just get both sizes for the top, just in case.
    (I don't remember it showing earlier )
    http://www.realoem.com/bmw/enUS/show...diagId=12_0258
    Tbd
    Aug 2013
    gainesville,fl.
    1977 320i
    Thanks guys. Probably trial and error.
    Nov 2007
    Cool
    I just had a look at my spare new ones, they are M10 x 70 mm Grade 10.9, I have the same installed, I measured all bell housing bolts and got spare new ones, all Grade 10.9. M8 for starter bolt thats a bit weak, all M10 is better.
    Randy
    Aug 2013
    gainesville,fl.
    1977 320i
    So, finally got a chance to get to this:
    The starter will not just push back in (one bolt stayed on the other fell out). I'm assuming the hears aren't lined up??
    Wondering, should I try to roll it in gear a bit and see if I can get it to slide in, or should I get the whole thing out to have a look at it?
    Happen to know the wrench size of the bolt next to the solenoid? I took off the runners to get access to it. But it looks easier from the bottom.
    Guess I'll try moving the flywheel some first.
    Ideas?
    Feb 2009
    District Nine
    sold 78 BMW 320i
    You need a long extension for the lower starter bolt, It should be 14mm or larger socket, or possibly allen-head socket.
    Tbd
    Nov 2007
    Cool
    Is this the same Starter Number that you were using before when it worked good and was fully seated ? Is this the same flywheel with same ring gear dimensions ?
    Randy
    Aug 2013
    gainesville,fl.
    1977 320i
    Quote Originally Posted by epmedia View Post
    Pretty sure I can get a spanner on it. Should've soaked it with penetrant, though. I'll have a better look tomorrow.
    Aug 2013
    gainesville,fl.
    1977 320i
    Quote Originally Posted by 320iAman View Post
    Randy
    The very same, it has been converted to 5 speed, who knows what else they changed (besides the drive shaft, of course).
    Looks like the bolt vibrated out, then I tried to start it with loose. The situation might be worse than I figured, but the flywheel should be okay. Should I have tried to push start it, first? I was afraid it would do damage, but now I realize it might not. Hmmm. Better just take it out of there, maybe it jammed up?
    It is a Bosch reman, has a sticker on it saying, "might not be the original model", but fits,works,etc.
    Nov 2007
    Cool
    Starters : 80- 83 320i use Bosch SR40X, 77-79 320i use Bosch SR71X Starters , charts show not compatible for either one to use the other. Flywheels are same D= 215mm 8 Loch- to 9/1982.
    Randy
    Feb 2009
    District Nine
    sold 78 BMW 320i
    Technically, the starter bolts to the engine block. It's just that the bolts extend through the bellhousing. According to realoem, the flywheels are identical up to 9/82, I'm not sure what's different about the flywheel on '83 models. So, we can safely assume if Dup's starter motor is for the 2.0 engine and his flywheel is pre '83 model - he's golden.
    For quick visual differences:
    2.0 starter parts
    1.8 starter parts
    http://www.realoem.com/bmw/enUS/show...diagId=12_0298
    Tbd
    Nov 2007
    Cool
    Not sure why it wont slide in all the way easy, it bolts thru the transmission bell housing and nuts secure the starter on the engine block , it should not contact anything, What 5 speed model is he installing,,Getrag 245 or Getrag 240 ?
    Im not sure of the differences between Bosch SR40X and SR71X, I have only installed the SR40X Starters and its housing or casing, which is the same for certain yr M5 starters--I have one of these new, backup 1 .
    I changed out my starter a few times,it slides right in,, Circular lip on starter seats into the bell housing and secures right in by bolt and nut.
    Maybe the circular lip on the starter is hitting something in circular bell housing area ?
    If the flywheel was off was a spacer involved ?
    Randy
    Feb 2009
    District Nine
    sold 78 BMW 320i
    Hi Randy, my post #14 was in reply to another post that appears to have been deleted. Please disregard my post #14.
    Tbd
    Nov 2007
    Cool
    Sure, waiting for Dups post on progress on getting it aligned and seated.
    Randy
    Mar 2013
    Santa Rosa, CA
    1981 320i silver
    Someone should do a side-by-side comparison of the difference between an SR-71 and an SR-40 (early vs late)
    They definitely specify different part numbers fir the early vs late models.
    Nov 2007
    Cool
    Yes, thats good idea.
    Bosch SR71X Fitment: BMW 12411466096
    BMW 2002 1968-1976
    BMW 2002tii 1972-1974
    BMW 320i 1977-1979
    More
    Bmw 320 2.0L 1977-1979
    Bmw 3.0S/3.0CS 3.0L 1971-1976
    Bmw 2002 2.0L 1966-1976
    Bmw Bavaria 3.0L 1972-1974
    Bmw 2.8 Bavaria 2.8L 1969-1971
    Bmw Bavaria 2.8L 1968-1971
    Bmw 2800 2.8L 1968-1974
    Bmw 2000 2.0L 1966-1972
    Bmw 2500 2.5L 1968-1971
    Bmw 1800 1.8L 1964-1971
    Bmw 1600 1.6L 1964-1967
    Bosch SR40X Fitment: BMW 12411466092
    BMW 1600 1968-1971
    BMW 1600ti 1968
    BMW 1602 1968-1971
    BMW 320i 1980-1983
    BMW 318i 1984-1985
    Something was changed.
    SR40XBS_Sr40X_Sid__ra_p.jpgSR71XBS_Sr71X_Sid__ra_p.jpg See the difference(s) ? Flanges Looks different in size, Solenoids different size, and nose piece looks different.
    Randy
    Aug 2013
    gainesville,fl.
    1977 320i
    Got the bottom but loose, it was a 17mm but. So, does the top bolt go the same way?
    What I mean is: the nut was tightened on the starter, not on the other side. Doesn't seem to matter much, but the bolt DID slide out, after all.
    Now, after getting it loose, the starter seem to slide right in. There's just one problem. The lower bolt hole on the starter cracked in half. Instead of throwing down the $150+ I'm thinking of reattaching it. I know, bad idea. Here's a picture:
    The kindle doesn't take very good pics, but you get the idea. The other bolt fell out, and this one wasn't torqued. So, on the last try the starter torqued and broke there. The bolt is pictured in the orientation in which I took it off. I guess I'm used to starter bolts that only screw into the housing; I can't recall having one with a but before.
    I guess it's worth a try, I just need something REALLY strong. Definitely not dollar store super glue. JB Weld?
    Mar 2013
    Santa Rosa, CA
    1981 320i silver
    Not good. Don't think you can fix that. It would be like using a starter held in by only one bolt.
    Feb 2009
    District Nine
    sold 78 BMW 320i
    It would need to be welded, but...
    That looks like a 1.8 starter. RA has a 2.0 starter for $48.00 (1 remaining) and others for $61+.
    Don't even bother with trying to glue it.
    fyi: the OE 2.0 starter housing is iron or steel (some aftermarket may be aluminum).
    Tbd
    Nov 2007
    Cool
    It can be welded, its aluminum welding, JB Weld or Aluminum Welding is an idea if you dont want to spring for a new or remanufactured one that fits.
    J-B Weld is The Original Cold Weld two-part epoxy system that provides strong, lasting repairs to metal and multiple surfaces. Mixed at a ratio of 1:1, it forms a permanent bond and can be shaped, tapped, filed, sanded and drilled after curing. At room temperature, J-B Weld sets in 4-6 hours to a dark grey color. A full cure is reached in 15-24 hours. J-B Weld has a tensile strength of 3960 PSI and sets to a hard bond overnight. It can withstand temperatures up to 550ºF when fully cured.
    Great For
    • Household Repairs
    • Automotive
    • Plumbing
    • Marine
    • Crafts & More
    Not sure how long JB Weld will last though.
    All the dimensions of SR71X and SR40X have not been compared as of yet, or the 1.8 and 2.0 Starter Block Holes in the Blocks, and Opening in the Bell Housing in the transmissions to put it all together with the position of the flywheel ring gear, then adding shims or notching to get the exact fit if necessary.
    Randy
    Mar 2013
    Santa Rosa, CA
    1981 320i silver
    Yes it looks like dups has the wrong starter, and $48 for a correct 2.0 starter is a deal, grab one.
    The starter you use should be the correct one for the block you have.
    SR71X for the early '77-'79 2.0L blocks and
    SR40X for the later '90-'83 1.8L blocks
    Aug 2013
    gainesville,fl.
    1977 320i
    Nope, this is the 71x: IMG_20171217_121442_hdr.jpg
    It looks skinnier than the original, maybe that was a part of the "premium quality remanufactured" sticker Bosch put on it.
    I think I will grab the RA starter though. Good catch on the deal, thanks.
  1. Where to find the indicator relay?
    By ANDYWILSON100 in forum 1988 - 1996 (E34)
    Last Post: 01-25-2005, 06:23 AM
  2. Where to find the Hamann tail lights?
    By Josh ///M Coupe in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-24-2004, 10:19 AM
  3. where to find the thermostat in 92 325i
    By ReVsHoT in forum 1991 - 1999 (E36)
    Last Post: 05-15-2004, 04:06 PM
  4. Where to find the "Arched" E36 Coupe Spoiler
    By andy415net in forum 1992 - 1999 M3 (E36)
    Last Post: 12-18-2003, 09:01 PM
