Results 1 to 1 of 1
Thread: New! Turner E9X M3 Aluminum Skid Plate
    Mar 2001
    Amesbury, Massachusetts
    BMWs and Mini's
    NEW - Turner E9X M3 Aluminum Skid Plate
    When it comes to the E9x M3 one of the most frustration maintenance points is oddly belly pan replacement.
    Since its low to the ground, the belly plans end up being an easy target for curb stops, inclines, and other road debris.
    The plastic material used in construction from the factory make this piece lightweight, but at the price of very limited strength.
    The engineers at Turner decided that they could design a strong skid plate and still be able to maintain the complex aero features found on the OE belly pan.
    We chose to use 3/16” thick 5052 Aluminum in the center and 1/8" thick aluminum side plates to get the most strength and maintain a reasonably lightweight for the skid plate portions, left, right, & center.
    The center plate design contains the same vent feature to maintain the intended design from the factory.
    We even raised the plates up higher to further reduce the chance of impact.
    This is all held together with 1018 steel brackets and a special fastener installed into the frame rails for maximum rigidity.
    All of this is protected using wrinkle black powder coat finish to maintain a sleek appearance and protect against corrosion.
    Want to know what it takes to install this awesome upgrade? Click HERE to view our install PDF.
    Click HERE for your Turner E9X M3 Aluminum Skid Plate
    Turner Motorsport
    / // Parts and Performance for BMWs
    16 South Hunt Road
    Amesbury, MA 01913
    800-280-6966
    info@turnermotorsport.com
  1. Replies: 1
    Last Post: 11-10-2017, 11:46 AM
  2. Replies: 1
    Last Post: 11-10-2017, 10:47 AM
  3. :: ECS Tuning :: NEW! Turner Aluminum Skid Plate BMW F8X M3/M4
    By ECSTuning in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 08-21-2017, 12:27 PM
  4. :: ECS Tuning :: NEW! E9X M3 Turner Delrin Bumper Protection Skid Plates
    Last Post: 08-08-2017, 01:39 PM
  5. Replies: 19
    Last Post: 09-09-2005, 02:44 PM
