Results 1 to 7 of 7
    Feb 2012
    Elkhorn wisconsin
    325i 330xi 740il
    2009 X5 3.0l E70 Power steering fluid
    Hello new to the X5 world here. Just picked up a 2009 X5 for the family. First thing I do with every new to me vehicle is change the fluids. I am getting mixed messages here.
    In the manual it says CHF 11s (same as my 740)
    The bottle on the car says ATF oil (assuming dextron III)?
    1 dealer says CHF 11s
    Another dealer says ATF oil and it must be plain ATF? Not really sure what that is.
    Napa says CHF 11s
    I’m sure I’m going to get a bunch of mixed messages here also but worth a shot.
    Thanks in advance!
    Jan 2016
    Montreal/Cape Coral
    2012 X6 35i
    Without a doubt, I'd go with the manual.
    2007 FJ Cruiser (best vehicle to date)
    2012 X6 35i Sport
    2013 ML350 BT
    2019 4Runner
    Feb 2012
    Elkhorn wisconsin
    325i 330xi 740il
    I’m kinda confused as to why they put a sticker on the bottle that says ATF oil only. Nobody can seem to give me a straight answer.
    Would it hurt anything if I flushed what ever is in there out and used chf11s if it was ATF fluid???
    Jan 2016
    Montreal/Cape Coral
    2012 X6 35i
    Read this and check the colour of your oil https://blog.fcpeuro.com/bmw-power-s...uid-atf-or-chf
    2012 X6 35i Sport
    2013 ML350 BT
    2019 4Runner
    Feb 2012
    Elkhorn wisconsin
    325i 330xi 740il
    The color is a yellowish Brown. Chf11s is green new and turns colors. ATF fluid comes in a variety of colors. They seem to both turn the same color eventually.
    Jan 2016
    Montreal/Cape Coral
    2012 X6 35i
    I'd flush out the system using the green stuff and stick with green.
    2012 X6 35i Sport
    2013 ML350 BT
    2019 4Runner
    Nov 2016
    Pasadena CA, USA
    09 X5
    Follow the manual instructions.
    If you are going to top up, use the exact same fluid as marked in your PS reservoir cap.
    If you’re planning to flush it completely, you can choose either.
    https://www.newtis.info/tisv2/a/en/e...supply/DsV56Jq
    If you live in a cold area, you should switch to Green fluid:
    https://www.newtis.info/tisv2/a/en/e...supply/1ECtZYt
  1. 2010 BMW X5 30i Power Steering Fluid Question
    By G33k in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 05-03-2013, 01:13 PM
  2. 2009 X5 3.0l Power Lift Gate Problem
    By agbullit in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-23-2012, 01:43 PM
  3. Symptoms of low power steering fluid???
    By seoulman in forum 1992 - 1999 M3 (E36)
    Last Post: 05-15-2002, 01:02 AM
  4. Replies: 5
    Last Post: 03-13-2002, 01:25 PM
  5. Power steering fluid leak...HELP
    By BimmerXTC in forum 1991 - 1999 (E36)
    Last Post: 04-18-2001, 10:04 PM
