RM European Auto Parts
Results 1 to 9 of 9
Thread: Driveshaft Seized what do I do ?
    Feb 2016
    Toronto
    '13 BMW 320i xDrive
    2004 X3 here. Mechanic saying he can’t remove the driveshaft to change the wheel bearings. The part is super expensive do you guys have any alternative part sources ? Cheapest I found was $500 and he’s saying he needs to force break 2 rear driveshafts
    2013 BMW 320i xDrive (F30)
    ~145,000kms
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Two rear driveshafts? The rear you can just loosen the collar and that will help compress the driveshaf.
    I think you are talking about the halfshafts, but if it is a driveshaft, check these guys out: http://www.driveshafts.com/products/...-Mercedes-Benz
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Feb 2016
    Toronto
    '13 BMW 320i xDrive
    It’s the rear driveshaft and apparently there’s 2 of them that he’s unable to remove to get to the wheel bearings.
    ~145,000kms
    dworthy's Avatar
    Nov 2010
    I think the tech is using the wrong terms. You have to remove the halfshaft to get to the bearing on the rear end, and of course there is one on each side. So 500 bucks would be about how much BMW would ask for a rebuilt halfshaft. I am wondering what seized, as there are 2 CV joints on the halfshaft, and I for one have never seen them seize up that I couldn't get them off.
    Darin
    Current:
    Past:
    M-Flight Member
    Aug 2017
    Menlo Park
    '05 ///M3
    You are probably referring to half shafts and/or drive axles. Those normally attach between the differential and the wheel bearing assembly.
    The driveshaft (which sometimes has 2 halves) attaches from transmission to the differential.
    Clarify.
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Yep. Halfshaft, aka "axle". 2 of them. and if the mechanic says he has to break them to remove them, I'm thinking you might want to find a different mechanic.
    Yes, I do recall them as being very tight, to remove, on an X3, but you let everything hang fully -- undo the sway bar, maybe even the shock. I seem to recall using a prybar to gain a bit of room between halfshaft and diff, then pushing the halfshaft UPWARDS, and rotating it out.
    There's really a whole bunch of stuff that you can unbolt and release, to gain some room there, without breaking the axles.
    EDIT: He will need to free up the inner halfshaft flange, and move it away from the diff BEFORE unbolting the main axle nut, and pushing the axle free of the wheelbearing/hub.
    Chris Powell
    BMWCCA 274412
    Aug 2017
    Menlo Park
    '05 ///M3
    I think to be fair, I think that nut on the axle is like 200+ foot pounds?
    dworthy's Avatar
    Nov 2010
    240/250ish ft pounds on that nut normally.
    But yeah if the guy doesn't know the difference between a half-shaft and a driveshaft, I too would be worried.
    Darin
    Current:
    Past:
    M-Flight Member
    Feb 2016
    Toronto
    '13 BMW 320i xDrive
    Thanks for the help guys. I’m gonna take it to another shop. All three lights on the dash are on simultaneously (4x4, brake light, and ABS). Previous mechanic told me its cause of the bearings being so bad that it impacts the sensors since their in close proximity.
    By the way I took the car to another mechanic and he said get ujoint is completely busted in the car. Whereas the first mechanic said the reason why there is play in the ujoint is because the bearings are so bad and it wiggles. Not sure what this all means but I really don’t wanna have to change a million things here. I hear a loud roaring noise from the back even crossing at around 20-30 kmh which indicates to me the bearings need replacement, but with these 3 idiot lights on at the dash and second mechanic telling me ujoint is busted I’m confused.
    Sometimes I wish the folks on this forum had a shop here lol
    ~145,000kms
  1. What do I do with my old driveshaft?
    By Hagbard in forum 1991 - 1999 (E36)
    Last Post: 04-29-2008, 09:30 PM
  2. Replies: 14
    Last Post: 07-18-2005, 05:32 PM
  3. What spare fuses do you have?
    By NormK in forum 1992 - 1999 M3 (E36)
    Last Post: 05-12-2001, 03:44 PM
  4. What body kit do u suggest besides the m3 one??
    By bob(NJ) in forum 1991 - 1999 (E36)
    Last Post: 04-06-2001, 02:33 PM
  5. What tires pressures do you guys run for auto-x?
    By Kevlar in forum 1992 - 1999 M3 (E36)
    Last Post: 03-15-2001, 02:39 PM
