Results 1 to 12 of 12
Thread: FS: FI S52 Engine
    Nov 2008
    Kelowna
    '99 M Roadster '08 135i
    FS: Built FI S52 Engine
    I’m selling the engine I had built for the ES/TS. I've removed and sold the t/s and the only reason I’m selling everything is I decided to go in a completely crazy and different direction! This means I can no longer use this setup. I did remove a perfectly great running setup with absolutely no issues. All the machine work was performed by a local shop that specializes in performance engine work from mild builds to pro-mod engines.
    I only put just over 6000 Km's or just a little over 3700 miles on the engine. I did perform a leak down and compression test a few weeks before I removed it from the car, compression was 190 for all 6 (done cold) and leak down was between 3 to 4% also done cold.
    I’m asking SOLD I'm willing to ship.
    I’m not looking to part out at this time.
    This is what was used for parts;
    CYLINDER HEAD,
    new valve guides
    new valve stem seals BMW
    new Supertech Black Nitrided Intake Valves
    new Supertech Inconel Exhaust valves
    new Supertech Single groove valve locks
    new Supertech Dual Valve Spring Kit with titanium retainers
    new lifters BMW
    new Schrick cams 264/256
    new chain tensioners BMW
    new chain guides BMW
    new VAC race timing chains
    new Torx exhaust studs
    new Stewart water pump
    new aluminum thermostat housing
    new 80 deg thermostat
    new Bavauto ignition coils
    new Beisan seal kit/anti rattle kit
    ENGINE BLOCK,
    new ARP 2000 head studs
    new ARP main studs
    new VAC oil pump with upgrade shaft and bolted gear
    new BMW oil squirters
    new VAC coated main bearings
    new VAC coated road bearings
    new crank bolt and washer
    new forged 10.5 Wiseco pistons/rings - with spacer gives 9.0 compression ratio
    new forged Eagle connecting rods with ARP 2000 bolts
    n
    ew cut ring head gasket with copper spacer
    new expansion plugs
    new BMW euro S50B30 oil pan/dipstick - holds 1Lmore oil and has baffles etc,
    MACHINE WORK,
    cleaned and pressure checked for cracks
    block bored and honed for 87mm
    block decked
    oil pump chain guide added
    cylinder head surfaced .002
    multi angle valve seats
    balanced crank, rods, pistons etc
    polished crank
    Nov 2008
    Kelowna
    Los Angeles, CA
    #Project333Ti & Z3 Coupe
    Really good deal here
    Nov 2008
    Kelowna
    Thanks for the kind words and the bump.
    Nov 2008
    Kelowna
    More photos added
    You can see the difference between the stock S52 pan (left) and the Euro pan (right).
    Nov 2008
    Kelowna
    Bump
    Oct 2017
    North Brunswick, NJ
    1998 M3
    Nice looking motor here. Very tempting.
    Nov 2008
    Kelowna
    Thanks. the asking price is obo
    Nov 2008
    Kelowna
    Weekend bump. I'm open to reasonable offers... I could really use the space!
    DC/FL
    Tesla MYP
    Nov 2008
    Kelowna
    PM replied!
    Aug 2014
    kentucky
    '98 Z3 M Roadster
    Payment sent!
  1. FS: S50 & S52 engine parts - L@@K
    By Dakar_M3 in forum Engines, Performance Parts & Software
    Last Post: 11-26-2008, 11:35 PM
  2. FS: '99 S52 Engine, Harness, DME, etc...
    By ///M3///M5 in forum Engines, Performance Parts & Software
    Last Post: 03-09-2008, 12:37 AM
  3. FS. complete s52 engine and tranny
    By m3boost in forum Engines, Performance Parts & Software
    Last Post: 12-09-2007, 11:59 PM
  4. Fs: 98 S52 Engine 77k
    By NAZ1998BMWM3 in forum Engines, Performance Parts & Software
    Last Post: 04-02-2007, 09:06 PM
  5. FS: 97 S52 engine harness and ECU
    By .Tom. in forum BMW Parts For Sale
    Last Post: 10-02-2006, 01:00 PM
