I’m selling the engine I had built for the ES/TS. I've removed and sold the t/s and the only reason I’m selling everything is I decided to go in a completely crazy and different direction! This means I can no longer use this setup. I did remove a perfectly great running setup with absolutely no issues. All the machine work was performed by a local shop that specializes in performance engine work from mild builds to pro-mod engines.
I only put just over 6000 Km's or just a little over 3700 miles on the engine. I did perform a leak down and compression test a few weeks before I removed it from the car, compression was 190 for all 6 (done cold) and leak down was between 3 to 4% also done cold.
I’m asking SOLD I'm willing to ship.
I’m not looking to part out at this time.
This is what was used for parts;
CYLINDER HEAD,
new valve guides
new valve stem seals BMW
new Supertech Black Nitrided Intake Valves
new Supertech Inconel Exhaust valves
new Supertech Single groove valve locks
new Supertech Dual Valve Spring Kit with titanium retainers
new lifters BMW
new Schrick cams 264/256
new chain tensioners BMW
new chain guides BMW
new VAC race timing chains
new Torx exhaust studs
new Stewart water pump
new aluminum thermostat housing
new 80 deg thermostat
new Bavauto ignition coils
new Beisan seal kit/anti rattle kit
ENGINE BLOCK,
new ARP 2000 head studs
new ARP main studs
new VAC oil pump with upgrade shaft and bolted gear
new BMW oil squirters
new VAC coated main bearings
new VAC coated road bearings
new crank bolt and washer
new forged 10.5 Wiseco pistons/rings - with spacer gives 9.0 compression ratio
new forged Eagle connecting rods with ARP 2000 bolts
new cut ring head gasket with copper spacer
new expansion plugs
new BMW euro S50B30 oil pan/dipstick - holds 1Lmore oil and has baffles etc,
MACHINE WORK,
cleaned and pressure checked for cracks
block bored and honed for 87mm
block decked
oil pump chain guide added
cylinder head surfaced .002
multi angle valve seats
balanced crank, rods, pistons etc
polished crank
