Results 1 to 5 of 5
Thread: Fault code 2E95 replaced alternator
    Oct 2017
    St. Louis mo. USA
    2005 545i
    So locales dealership told me my alternator was bad and was overcharging the system so I decided to change the alternator. Fast forward new alternator installed car still has same code of 2E95 generator current problem present I reset the code start the car re check code same fault code appears almost immediately. Could I possible have a defective alternator or something else. I bought a car quest brand alternator.
    Dec 2015
    Brighton, MI
    2005 645ci
    Did you ever figure out what was going on with your charging system? I've been having the same problem.
    Jan 2016
    Ca
    2001 525it
    Certainly replacement alternators can be bad
    DE, USA
    '15 435i,'10 535i,'08 X5
    Alternator may have been rebuilt w/wrong regulator....one that doesn't respond to BSD signal from DME.
    Apr 2012
    These alternators are NOT your old time AC Delco alternators. My original went bad (oil dripping into the windings from upper timing cover leak) and I replaced it with a reman Valeo from NAPA. They didn't have the equipment to test BMW alts - installed and was getting random voltage spikes, and modules restarting themselves.. Took a while monitoring it live with driving to see the voltage spike near 16, then trip the computers out. I would even get shift lever malfunctions etc. Replaced again, and the car is problem free.
  1. Replies: 15
    Last Post: 10-13-2017, 02:03 PM
  2. Replies: 3
    Last Post: 05-09-2007, 07:42 PM
  3. Replies: 4
    Last Post: 02-26-2007, 10:47 PM
  4. Replies: 8
    Last Post: 12-03-2006, 08:49 PM
  5. fault code. What to replace? Thanks
    By 12:03 in forum 1992 - 1999 M3 (E36)
    Last Post: 01-24-2006, 12:29 PM
