Page 2 of 2 FirstFirst 12
Results 26 to 31 of 31
Thread: Need advice for removing stubborn bolts
  1. #26
    Jan 2006
    Ft. Lauderdale, FL
    98 740il, 00 540i,04 ZHP
    Just thinking out loud here...heating metal causes it to expand. Heating the stud will cause it to expand in the threads, which technically would make it harder to remove. Wish I could be of more help...
  2. #27
    new york
    1999 750il, 1995 325i, 1995 trans am, 1985 corvett
    Hi Racer,
    I believe the intense heat and expansion should help break the bond and dissolve the electrolysis and once it cools slightly...the bolt should be much easier to loosen.
    At least in theory...this is the way it should work. I certainly hope I am right...buying the bolt buster is not cheap.
  3. #28
    Oct 2016
    Portland, OR
    1998 740il
    I've never played with such a tool. I hope it works well!
    Maybe if it fails to deliver you can return it to Amazon? If it solves your problem, money well spent.
    1998 BMW E38 740il - Vermont Grün Metallic, 150k miles, all stock. 11/98 build.
    2011 Range Rover Supercharged - Rimini Red, Jet/Jet Interior.
    2018 Mercedes GLE 350 - Diamond White, Soccer Mom kid-hauler.
    1970 Chevy Chevelle - Pro-touring, 496ci BBC, custom everything.
  4. #29
    Feb 2014
    Pacifica. ca
    2001 BMW 740il
    I have an old bolt buster that has saved me numerous times with frame bolts, exhaust bolts, manifold bolts especially, and others. The bolt buster 2 has an even better coil and more wattage from what I have been told. I also bought a mini ductor for tighter spaces. Safer obviously than a torch and more pinpoint. After about 10 seconds that bolt/nut are nice and toasty. And I use a thermal blanket to protect adjacent areas when needed.
  5. #30
    new york
    Hi Lewvirg,
    Ive never used the bolt buster but the reviews seem very positive. I just hope this tool will allow me to heat the remaining 1 inch of broken bolt enough to transfer the heat into the section of threads that are in the aluminum cylinder head.
    Based on the videos...this tool should be able to do that within a few seconds. The remaining bolt stud I am heating is only 6mm so its not as large as the bolts on the videos. I plan to heat the stud just enough to make it a dull red color and then allow it to cool down before spraying it down with a can of CRC freeze off. I figured the heat from the tool will allow the steel threads to expand within the aluminum cylinder head and burn of the corrosion and once the stud cools down....I can spray the cooling agent to help the threads shrink away from the aluminum head before using a vise grip to loosen it. I sure hope my logic is correct...running out of ideas
    Thanks again for the good advice.
  6. #31
    Feb 2014
    Pacifica. ca
    2001 BMW 740il
    Quote Originally Posted by 1999750il View Post
    Hi Lewvirg,
    I am not sure that I would use a quick cool down with aluminum involved, but that's my own paranoia about aluminum heads. When I wanted to crack a bolt/stud - that's the procedure on iron/steel - use the air duster cans upside dow and spray the bolt/stud. My first is to let it go from red to cooler then spray Kroil wait a few seconds gently turn the bolt, if no give, try spraying again. Then tap with a light hammer while turning. Usually a combination of these methods, plus alot of swearing, and patience will get it removed. Make sure that you use eye protection - not saying you don't, but i've seen a lot of guys doing these kinds of things without and all it takes is a small splinter if a hammer is involved.
    if that doesn't do it, see if there is a local mobile welder service - they can come out and tig something up to get it out. just as an aside, if your going to be doing work on cars for a long time, get a good mig welder off of ebay (easy to learn) no more stubborn bolts then. Then you'll find yourself wanting to get a TIG LOL. Beats the old days of O/A and stick - though they still have their places.
    hope this helps.
  1. Replies: 0
    Last Post: 08-15-2010, 11:40 AM
  2. PS line: suggestions for removing stubborn banjo bolt
    By petenice00 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-13-2009, 06:48 PM
  3. need advice for law school!
    By mrclam in forum Off-Topic
    Last Post: 10-03-2002, 11:14 PM
  4. Need advice for a potential buyer of a 318
    By AgileM3 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-09-2002, 07:25 PM
  5. need advice for a "Large German Sedan"
    By Dark Helmet in forum 1995 - 2001 (E38)
    Last Post: 02-23-2002, 11:44 AM
