Page 2 of 2 FirstFirst 12
Results 26 to 35 of 35
Thread: Suspension noise
  1. #26
    Jun 2016
    Perrysburg, Ohio
    1999 BMW M3
    Changed the shock mount and no more noise... I also put the reinforcement plates on. Now heatercore is leaking but good thing is a friend of mine has done it on his car and is charging me a very good deal for the amount of things that need to be removed in order to replace the heatercore.
    Current
    1999 BMW M3/2/5 cosmos/black vaders
    Past
    2000 BMW M5, Jetblack
    1995 BMW M3/2/5, Alpine white
    1997 BMW 328/5, Boston green
    2005 BMW 330/6 ZHP, Silbergrau
    1999 BMW 540/6, Cashmere beige
    2000 BMW 328/5, 144k miles sienna red (slicktop)
    1995 BMW Dinan M3/2/5, Dakar yellow (I regret it)
    2002 BMW 530iA sport, Jetblack
    2001 BMW 530iA sport, cosmos
    2002 BMW 530iA, sterlinggrau
  2. #27
    Oct 2003
    Seattle
    99 M3
    Hopefully it wasn’t stock length shocks that blew out your old shock mounts…
  3. #28
    Jun 2016
    Perrysburg, Ohio
    1999 BMW M3
    Quote Originally Posted by bluptgm3 View Post
    That is the cause.... Front's have bilsteins and rear are stock... I'm remeding that this fall
    Current
    Past
  4. #29
    Feb 2018
    Indio, Ca
    1999 BMW M3 Convertible
    Thanks for this thread. If I order the rogue or ground-control rear mount can I still use the the sachs SHOCKS that I already purchased. I'll call the cheap reinforcement plates and meyle strut mounts a loss. When will I learn to ask you guys before I pull the trigger on ebay?
    Sent from my SM-N950U using Tapatalk
  5. #30
    Aug 2013
    1999 BMW M3 Coupe
    The aftermarket Rogue/GC/Bimmerworld mounts are designed to work with basically any shock made to fit on this car, so yes it should fit. If the shock would've fit on the stock mounts, it will fit on the new ones.
  6. #31
    Jul 2011
    Austin, TX
    S54 E36 M3, E32 740il
    Quote Originally Posted by jprottas View Post
    No reason to call that a loss. I did that almost 7 years ago and have had zero trouble since then. While factory shock mounts are the best, they're just fine, and the "cheap" reinforcement plates will do the job just fine as long as they're not made from aluminum foil. They're effectively just a big washer.
  7. #32
    Feb 2018
    Indio, Ca
    Quote Originally Posted by blckstrm View Post
    But I understand the rogue/bimmerworld mounts would give me easier access to change the SHOCKS next time, which is already trickier since I have a convertible
  8. #33
    Feb 2018
    Indio, Ca
    I'll repeat for blueptgm3 - you need to get the Z3 reinforcement plates. Unless you WANT to have to weld them later, this is a case of an ounce of prevention worth a pound of cure. They're $20-$30 for a pair. This would be one of the first (and easiest) things I'd do if I ever had to get a new car.
    Is this what you're suggesting:
    http://www.bimmerworld.com/s.nl/c.37....A/id.17757/.f
    Do these cover the e46 and z3 reinforcement plates you're talking about?
    I have a 1999 m3 convertible and mostly want the easier lower replacement option but also want the max protection against torn towers
  9. #34
    Feb 2018
    Indio, Ca
    Quote Originally Posted by TostitoBandito View Post
    Is any one of these 3 better than the other - I plan on using stock 10mm shocks
  10. #35
    Aug 2013
    1999 BMW M3 Coupe
    I have the GC mounts and they're fine. From what I understand the Rogue mounts are basically the same thing. The basic concept is there's the main part of the mount which assembles around the top of the shock and contains the bushing, and then there's a steel plate with the two bolts welded to it which sandwiches in from the top with the car's shock tower in between. The plate with the bolts drops in from the trunk so that once installed if you ever need to remove the shock you can do it from under the car without needing to de-carpet your trunk again. I'm not as familiar with Bimmerworld, so someone else will need to chime in there.
    This is the reverse of the OEM mounts which have studs which stick up into the trunk from below and require trunk access to get to the nuts.
  1. YES! Rear suspension noise finally fixed!!
    By Eric Giles in forum 1992 - 1999 M3 (E36)
    Last Post: 04-15-2005, 10:45 PM
  2. Front drivers side suspension noise?
    By hatchimon in forum 1991 - 1999 (E36)
    Last Post: 03-16-2004, 11:52 AM
  3. help with suspension noise
    By 318power in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-13-2003, 07:28 PM
  4. Suspension noises...need your help...
    By sunir in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 11-01-2002, 10:41 AM
  5. HELP! squeaky steering and rear suspension noise
    By BimmerXTC in forum 1991 - 1999 (E36)
    Last Post: 04-02-2001, 05:12 AM
