Results 1 to 25 of 35
Thread: Suspension noise
    Jun 2016
    Perrysburg, Ohio
    1999 BMW M3
    Suspension noise
    Hi guys, I recently bought a 1995 BMW M3 coupe, 5spd. I bought the car this way.. whenever you go on top off a bump there's this noise. Link of the video:-
    https://drive.google.com/file/d/1qbF...ew?usp=sharing
    Is it the rear shock? This is the side where the noise is coming from
    Yes, I know lowering springs and OE shocks don't go along together
    Current
    1999 BMW M3/2/5 cosmos/black vaders
    Past
    2000 BMW M5, Jetblack
    1995 BMW M3/2/5, Alpine white
    1997 BMW 328/5, Boston green
    2005 BMW 330/6 ZHP, Silbergrau
    1999 BMW 540/6, Cashmere beige
    2000 BMW 328/5, 144k miles sienna red (slicktop)
    1995 BMW Dinan M3/2/5, Dakar yellow (I regret it)
    2002 BMW 530iA sport, Jetblack
    2001 BMW 530iA sport, cosmos
    2002 BMW 530iA, sterlinggrau
    Dec 2005
    Virginia
    1997 M3, 2012 C63
    Peel back the trunk carpet and check out the rear shock mount then push up and down on the rear again. If you are lucky the the shock mount needs replacing or the bolt might just need tightening. if you are unlucky the shock tower itself could be ripped.
    Jun 2016
    Perrysburg, Ohio
    1999 BMW M3
    Quote Originally Posted by realjones View Post
    Now How do I remove the carpeting? I got majority off it out but i can't seem to get it out off the black box on the top or by the spare tire
    Current
    Past
    Jun 2008
    Surf City, NC
    1995 Dakar M3
    Quote Originally Posted by Ajcanadian View Post
    You are gonna need to carefully take off the rear speaker covers from inside the car then unscrew the rear speakers.
    After that you will beable to remove the speaker boxes from the trunk.
    Jun 2016
    Perrysburg, Ohio
    1999 BMW M3
    Quote Originally Posted by fbmbirds View Post
    Turns out I do not need to do that you can get the carpet off with a lot off patience without ripping it off.
    https://drive.google.com/file/d/1nB4...ew?usp=sharing
    Found it need the mounts
    23516163_10208475605686374_2124102491_o.jpg23548165_10208475586485894_32961750_n.jpg23558134_10208475602206287_252565456_o.jpg
    on a side note how bad do the towers look? I will be getting meyle mounts and reinforcement plates
    Current
    Past
    Aug 2013
    1999 BMW M3 Coupe
    Towers should be fine as long as they are free of rust and cracks. I'd strongly suggest replacing the original mounts with aftermarket mounts that sandwich/reinforce and have the bolts welded in from above so you don't need to take out the carpet to replace your shocks (can do it from below). I know both Ground Control and Rogue make mounts like this.
    Jun 2016
    Perrysburg, Ohio
    1999 BMW M3
    Quote Originally Posted by TostitoBandito View Post
    I ordered meyle mounts and plates.... But it does have a little cracking shown in pics
    Current
    Past
    Aug 2013
    1999 BMW M3 Coupe
    It's hard to tell from the pictures if that is just surface/paint or an actual crack in the steel. If there's actually damage to the metal I'd advise getting it professionally repaired. If you just put in new shock mounts and there's existing cracking, they'll just keep getting worse.
    Oct 2003
    Seattle
    99 M3
    Suspension noise
    You will be sorry using Meyle Rear Shock Mounts. Use Rogue, Turner, Ground Control, or other aftermarket RSM, though I recommend E46 M3/Convertible RSMs and Z3 Reinforcement Plates.
    If your Rear Shock Tower is cracked or torn, have it professionally repaired.
    Jul 2011
    Austin, TX
    S54 E36 M3, E32 740il
    Quote Originally Posted by bluptgm3 View Post
    I'll repeat for blueptgm3 - you need to get the Z3 reinforcement plates. Unless you WANT to have to weld them later, this is a case of an ounce of prevention worth a pound of cure. They're $20-$30 for a pair. This would be one of the first (and easiest) things I'd do if I ever had to get a new car.
    Jun 2016
    Perrysburg, Ohio
    1999 BMW M3
    I just ordered ECS tuning reinforcement plates. If I throw them on with the mounts will that stop any more damage?
    For real? I had a fellow E36 M3 owner recommend them to me so I bought them along with ECS tuning reinforcement plates.... Will the reinforcement plates after installation with the new mounts cause any more damage?
    Quote Originally Posted by blckstrm View Post
    I ordered ECS TUNING reinforcement plates. I'm going to put them on with the mounts when they arrive. Now my question is will the crack worsen with the reinforcement plate?
    Current
    Past
    Jul 2011
    Austin, TX
    Depends on where the cracks are. There are no washers of any kind, which is why the sheet metal fails. The nuts pull through the sheet metal. The reinforcement plates are really just big, fitted washers. On mine, one side tore through. I didn't have a welder, so I just threw the plates on (Which was bad). It actually pressed the ripped metal back into place, which made it easy to weld later.
    But all my damage was under the reinforcement plate - the two nuts on the driver side ripped through. And it COULD have gotten worse - it just didn't.
    I can't really tell on yours. But if there's just a crack, it's easier to fix now than after it REALLY rips. That doesn't look like damage to me, though - just dirt.
    Jun 2016
    Perrysburg, Ohio
    1999 BMW M3
    My friend has a welder and we'll see what we can do. If he says its not too bad we'll just throw the reinforcement plates on. It's just a hairline crack that it. Not even that deep and right now the car isn't even driven
    Current
    Past
    Aug 2013
    1999 BMW M3 Coupe
    Meyle are OEM replacement, more or less. The aftermarket Rogue/Ground Control/TMS mounts are heavier duty, should last forever, and make it 100x easier to service your rear shocks since you no longer have to go into your trunk to get at the bolts since the only nuts are underneath and the studs are welded to the plates. Also, the aftermarket mounts often more or less have the reinforcement plates integrated. I know with my Ground Control plates I have no reason to use the reinforcement plates since the mounts have basically the same amount of steel sandwiched around the shock tower. The aftermarket mounts are more expensive, but not that much more. It's really a no brainer in my opinion.
    Jun 2016
    Perrysburg, Ohio
    1999 BMW M3
    Only if I knew this before ordering my parts
    Current
    Past
    Jul 2011
    Austin, TX
    You could always return them and order the aftermarket ones unless you're in a huge hurry.
    Oct 2003
    Seattle
    99 M3
    Suspension noise
    Rogue Engineering sells a RSM Reinforcement Plate with welded in fasteners p/n “RSM.PLATE”.
    Knock the studs out of the Meyle RSMs and use the Rogue RSM Plate, I do not recommend the Meyle RSMs, but I do recommend the E46M3/Convertible RSM, with the same treatment.
    Jun 2016
    Perrysburg, Ohio
    1999 BMW M3
    Rogue Engineering sells a RSM Reinforcement Plate with welded in fasteners “RSM.PLATE”.
    Knock the studs out of the Meyle RSMs and use the Rogue RSM Plate.
    Good idea... the e36 life is so much different.
    Current
    Past
    Dec 2005
    Virginia
    1997 M3, 2012 C63
    Your car made it over 20 years without reinforcement plates. I had a simple setup of e46 shock mounts with z3 reinforcement plates for many years and had no issues.
    I agree that the rogue are better, but for now you certainly can put some fresh ones on there (if it is not worth returning them) so you can drive the car and decide what else you want to do with it. What where the Meyle RSM like $30? With a blown RSM wouldn't surprise me if your rear shocks/RTABs are due too.
    Oct 2003
    Seattle
    99 M3
    …and you need to replace those stock rear shocks. Since you are running lowering springs, they potentially will bottom and tear your Rear Shock Towers.
    Additionally, the free travel of leaking/worn shocks can act as a hammer when the shock “sees” dampening in the travel.
    Aug 2013
    1999 BMW M3 Coupe
    It's a "do it right, once" thing. $40 for stock or like $80-90 for aftermarket with integrated reinforcement and easier to service. In a lot of cases I'm all for going all OEM on a street car, but there's a few places where aftermarket is actually better bang for the buck and maintains stock NVH and appearance with increased performance and/or longevity. RSM's, cooling system, poly bushings in certain places (pedals, shifter), speakers, brake pads/rotors, front underpanel, etc...
    Yeah and as for RTAB's/shocks, welcome to the suspension refresh adventure. You can take it as far as you care to.
    Jun 2016
    Perrysburg, Ohio
    1999 BMW M3
    I just wished the guy changed the rear shocks too. Like he spent so much money why didn't he just put bilstein shocks on the back? There's bilstein on the front but stock on the back. My plan is to run the car this way until summer and then buy koni yellows.
    Correct, but funds are a little tight for me right now. That'll happen hopefully during the fall.
    Exactly, I totally now understand this. A fellow from the land of Brits offered me to buy the Meyle that he bought on his car so I bought those.... with ecs reinforcement plates. That's how I'll drive the car for now. Also, we're welding the shock towers when we install the mounts. Coming fall koni yellows are going to go on.
    Current
    Past
    Oct 2003
    Seattle
    99 M3
    You may not make it till fall on stock/stock length rear shocks. They may tear your Rear Shock Towers.
    Replace those (dead) shocks and don’t mix Koni w/Bilstein.
    LOL!! If the car moves to left or right under hard acceleration first/second gear and returns on deceleration it needs RTABs.
    Jun 2016
    Perrysburg, Ohio
    1999 BMW M3
    It does not however it does spin in third gear... Son of a biscuit... I gotta wait until Christmas for the shocks
    Current
    Past
    Jun 2016
    Perrysburg, Ohio
    1999 BMW M3
    Update just got some parts in the mail, more to come. For now I got the meyle rear shock mounts, ECS tuning reinforcement kit, Liqui moly engine flush & supposedly Liqui moly molygen oil service kit with a UV light... but my terrible luck they sent me regular liquimoly since molygen 5w30 is out but hey on the brighter side I got a partial refund.
    Current
    Past
  1. YES! Rear suspension noise finally fixed!!
    By Eric Giles in forum 1992 - 1999 M3 (E36)
    Last Post: 04-15-2005, 10:45 PM
  2. Front drivers side suspension noise?
    By hatchimon in forum 1991 - 1999 (E36)
    Last Post: 03-16-2004, 11:52 AM
  3. help with suspension noise
    By 318power in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-13-2003, 07:28 PM
  4. Suspension noises...need your help...
    By sunir in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 11-01-2002, 10:41 AM
  5. HELP! squeaky steering and rear suspension noise
    By BimmerXTC in forum 1991 - 1999 (E36)
    Last Post: 04-02-2001, 05:12 AM
