Up to 20% OFF Cool Carbon Brake Pads
New Cool Carbon S/T Plus Compound has the GG rating and higher friction level than the original S/T pads. Developed to fill the gap between entry-level performance and competition pads, these brake pads offer better stopping power and torque without sacrificing street drivability.
The S/T Plus Compound features a new formulation with Twaron aramid content in the composite, providing greater thermal stability and better durability than comparable pads. This compound was developed in a dedicated manufacturing facility using a proprietary process of unique curing and triple scorching for a shorter bedding time.
With a better bite and greater linear stability, these longer-lived pads offer lower noise and brake dust over other high-performance alternatives and are designed to perform even with street tires.
With stability in temperatures exceeding 600C, Cool Carbon S/T Plus Compound pads are perfect for canyon carving, spirited driving, or light to medium track use! Use these front pads with original S/T rear pads for the optimal balance.
Street Performance/Track Tuned (S/T) pads from Cool Carbon feature a substantially higher friction level over the OE pads. Better stopping power and torque with stability in cold or hot temperatures exceeding 450C is easy thanks to the special “hollow” ceramic structure of the pads, which exponentially increases the ability to dispel heat.
Minimal noise under normal driving conditions come from the constrained layer noise shims featured with these pads, and the better feel under your brake pedal means more feedback and control during standard or spirited driving, giving you the sure-footed confidence required to enjoy your performance car. With long life, excellent fade resistance, and a low dust level, Cool Carbon S/T pads are fantastic for your European performance car.
Click HERE for your Cool Carbon Performance BMW Brake Pad Upgrades
Turner Motorsport
/ // Parts and Performance for BMWs
16 South Hunt Road
Amesbury, MA 01913
800-280-6966
info@turnermotorsport.com
