Bavarian Soundwerks
Results 1 to 4 of 4
Thread: Is there a antifreeze sensor in my 2007 X3? My heat is not working.
    Nov 2017
    Pa
    2007 X3
    Please help,
    i just bought a 2007 X3 and found out that there is no heat. The blower works but the air is cool. Someone said it cause be low antifreeze but my other friend said that there should be a sensor light on the dash.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The light on the dash indicates when the coolant is low. However, no system is foolproof. The first thing is to check the coolent level at the expansion tank under the hood. It should have an indicator rod that floats in the coolant.
    The flow of hot coolant to the heater core is controlled by the climate control module (IHKA in BMWeze). Basically, it opens and closes the heater control valve located in the engine compartment. The valve is open unless the IHKA supplies it with 12VDC. That valve could be blocked.
    The cooling system in these cars must be maintained properly. Failure to so can result in an expensive paperweight, an overheated BMW engine. Find a reputable indie shop that specializes in BMWs. Try www.bimrs.org.
    Feb 2001
    So Cal
    1997 M3 Sedan
    And although it is probably obvious, the engine has to be warm in order to have any heat.
    97 Estoril/Black M3/4/5
    "Although we've experienced an M3 sedan with an automatic, our test car came fitted as God intended, with a 5-speed manual ..."
    Road & Track May 1997, testing the M3 Sedan
    Wadsworth, Ohio
    BMW
    Check the level and bleed the system properly. You may have an air pocket in the heater core.
    -James
  1. My 328i 2007 is jerking when I am in idle...dealer cannot diagnose and will not fix.
    By cmac91083 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 07-30-2018, 01:36 AM
  2. Is there a trustworthy dealership in my area ??
    By micsteam in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-01-2011, 10:09 AM
  3. Is there a DIY section in this forum?
    By WhiteTrash in forum 2001 - 2006 M3 (E46)
    Last Post: 08-20-2003, 11:14 AM
  4. Is there a BMW dealer in/near Lexington, Kentucky?
    By ThumperAC in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-05-2002, 08:10 AM
  5. Is there an 02 sensor on my 1991 m3?
    By bmw325is in forum 1987 - 1991 M3 (E30)
    Last Post: 06-26-2002, 05:15 PM
