So I finally flashed to manic stage 2. I'm curious if a wot box would still send it screaming into limp mode on a flashed ECU. But I can't seem to find a wiring diagram or color code for the r56 mini. I need to find the location and color of these 6 wires. Or at least if they share the same wire color as an R53. These are the wires I need to find the location and color of these wires
1. Ignition coil power IN
2. Clutch wire input
3. Throttle position sensor or accelerator pedal position sensor input
4. RPM input any connection to Fuel Injector Drive Signal or Ignition Control Signal
5. Ignition coil power OUT
Sent from my SM-G935U using Tapatalk
