I need a set of non-staggered wheels for my winter setup. Naturally I turned to Craigslist.
I found a guy selling a set of 17" style 306 wheels. He claims they came from an F30 328i, but all the research I've done indicates that style 306 came in 16" on the F30, and that 17" style 306 came only on the X3.
Can anyone clarify? Does anyone know the offset?
I'm hoping to fit these wheels on my E90.
Attached: photos from the seller's ad.
http://www.bmwstylewheels.com/bmw/306
In the picture you provided with the specs, the wheels are 17x8 +43 offset.
According to this post, http://www.e90post.com/forums/showthread.php?t=464, for the e90 in 8" wide wheels the highest offsets were +37. The only issue I could see would be needing to run a small spacer in the front with longer wheel bolts if you run into the wheel hitting the strut.
The rear wouldn't be a problem, e90s also came with 19x9 +39 which if you ran the wheels you are considering buying you would gain inner clearance.
Some of those cars do have larger brakes. Which actual car do you have> I can check the offset range of the wheels we carry.
