Page 2 of 4 FirstFirst 1234 LastLast
Results 26 to 50 of 81
Thread: 2001 S54 M Coupe Rebuild
  1. #26
    Norristown PA
    mostly bmw
    Thank you. Slowly but surely. I do have one of my employees helping me with some of the disassembly, so that helps. =)
    Before BMWs I use to mess around with old Ford trucks, Jeeps and RRCs. Done my fair share of lifting. With my BMWs I find that the factory M suspension is good enough for me.
    95 turbo 330ti. 01 maxpsi m3 e85. 01 m5. 01 m coupe. 03 AIM 996t e85. 06 x3 w/Meyers plow and winter daily. Prussian Motors is hiring!! prussianmotors.com/jobs
    Current e39t LS Turbo swap: https://www.bimmerforums.com/forum/s...LS-e39-Touring
  2. #27
    Norristown PA
    mostly bmw
    Got the engine back from the machine shop. They did very minor decking and honing. Figured I'd put some ARP 2000's in the rods while I had it apart.
  3. #28
    Norristown PA
    mostly bmw
    Ignition is out. Needed nothing more than a cleaning. I'll add some nice Wurth lubricant and put it back in.
  4. #29
    Jul 2004
    Houston, TX
    36 Cylinders
    Wow that car was deep underwater. But I am sure it was cheap enough then.
    Good work here! I like the updates.
    Kind of glad my Harvey rescue wasn't that deep. I've been driving it for 2 months now.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  5. #30
    Norristown PA
    mostly bmw
    It was completely submerged. I don't know what your definition of cheap is, but it is the most expensive car I've ever purchased at an auction. ...and I've bought totaled e90 m3s, e60/e63 s85, f10 N55 cars. =/
    I'm not fixing it to sell. However, I am hoping/thinking the S54 clown shoes will only continue their rise in value. =)
  6. #31
    Dec 2007
    Charlotte, NC
    1999 M3, 1999 Z3M Coupe,
    Hope the resto works out for you! Great car...
  7. #32
    Apr 2002
    Florida
    Coupes...
    I have a full M Coupe wiring harness complete pulled from the race car if you need one.
    Everything from the fuse box to the tail light plugs.
    If you think that will help, send me a PM.
    White is Right, Steel Grey is OK, but Estoril is the only color that truly matters.
    I like Coupes.
  8. #33
    Norristown PA
    mostly bmw
    Been very busy with work etc, but it's starting to look like an engine again.
  9. #34
    NY
    skateboard
    Awesome work going on here.
  10. #35
    Norristown PA
    mostly bmw
    Thank you GG.
    Forgot a picture of the shiny pistons and cylinder walls.
  11. #36
    Jul 2004
    Houston, TX
    36 Cylinders
    Progress looks awesome. The hard work will be worth it. It will be like new.
    -Abel
  12. #37
    NY
    skateboard
    Quote Originally Posted by bubela View Post
    Thank you GG.
    So much fancy.
  13. #38
    Norristown PA
    mostly bmw
    Nipping away at it.
  14. #39
    Norristown PA
    mostly bmw
    Gosh.. this is taking a little longer than I expected.
    I power washed the engine bay. Still have some detailing to do.
  15. #40
    mherington is offline Passing Gas... BMW CCA Member
    Duluth, GA USA
    1999 Z3 M Roadster
    Have you been able to get a sense for the condition of the electrics? How do the harnesses and plugs look? Computers, alternator, starter, etc?
    Great progress, it’s a treat each time an update comes through!
    M
  16. #41
    May 2013
    PA
    1972 BMW 2002tii
    I moved my long-long term project off my "personal" project lift to make room for the z3m. Figure it's going to be on the lift for a while as the engine gets rebuilt.
    Attachment 615446
    Nice long term project ! Best of luck with the Coupe. You should be getting a nice holiday card from the parts guys!
    www.classicvelocity.com
  17. #42
    Norristown PA
    mostly bmw
    Quote Originally Posted by mherington View Post
    M
    I assessed the modules and wire plugs when I first got the car. All the important ones (DME, ABS, etc) had almost no corrosion. I mean maybe a couple pins had any at all. I was very optimistic at this point. All the ones on the engine harness are fine. The little rubber gasket in the plug seems to have done its job. I never tried to start the car while it was still together. I think the only thing I did was put the window down so that I didn't get locked out again!
  18. #43
    Feb 2008
    Ventura - Baltimore
    01MCoup-02WRX-04MCS-86TV
    what a cool thread!
    1999 - S52 - E36/8 - Alpine White over Imola Red
  19. #44
    Aug 2013
    San Francisco CA
    00 Imola E/S TS M Coupe
    Talk about a project! Excited for all the updates though. Great job so far!
  20. #45
    Jul 2004
    Houston, TX
    36 Cylinders
    I assume this will be alive soon!
    -Abel
  21. #46
    Norristown PA
    mostly bmw
    If I busted my hump, I could probably have it running next weekend. Sadly, other things are doing that for me instead. I did get to work on it a little today. Just cleaned up a little and replace the power steering lines.
    I still have to find some bolts to secure the ignition switch. Haven't found the right size yet. I have a 13 mm head, but would like to find a 10 mm head with the same thread so I can get a wrench on it and not hit the sides of the mount.
    Engine is basically ready to go in.
  22. #47
    Norristown PA
    mostly bmw
    Sunday plans got canceled. So this happened:
    I just pulled a recently replaced clutch, flywheel and pressure plate from a 2006 m3. So that's here now in place of the rusty one care-of: Houston rain water.
  23. #48
    Jan 2014
    Moreno Valley CA
    2000 bmw m roadster
    Are you parting out an s52., could use some interior parts
  24. #49
    Norristown PA
    mostly bmw
    Sorry, no coupe parts for sale. Roadster parts for days.
    I did get the car together yesterday. Ran my check list and turned the key late last night. No start. I wasn't really expecting it to start on the first turn of the key but at least it turns over. I checked and the fuel pump fuses are seeing 12v, but not sending a signal to the pump to turn on. I'll hook it up to the GT1 tomorrow hopefully. Taking a sunny Sunday afternoon off!
  25. #50
    Norristown PA
    mostly bmw
    IT'S ALIVE!!!!!
    HUGE thanks to Jim at Kassel Performance. www.kasselperformance.com
    I tried with the original DME, but it was not communicating. So, I sent a DME I had on the shelf to Kassel. He worked his magic and the car started right up. The engine purrs like a kitten. I still have to put a new rail on the driver seat, but after that, I should be able to break it in!
    Wow.. feels so good.
  1. Z3 E36/7 FS: 2001 S54 M Coupe
    By 930LDR in forum 3 series & Z Series
    Last Post: 07-04-2010, 07:32 PM
  2. Z3 E36/7 2001 S54 M Coupe For Sale
    By 930LDR in forum Z3,Z4,Z8 Classifieds
    Last Post: 04-23-2010, 01:33 PM
  3. WTB: 3.15 LSD from a 2001 S54 MZ3 Coupe/Roadster
    By Stück in forum BMW Parts Wanted
    Last Post: 11-30-2008, 01:38 PM
  4. FS 2001 S54 Z3M coupe $27,500!!!
    By eZg in forum BMW Cars For Sale / Wanted
    Last Post: 02-27-2007, 08:55 AM
  5. 2001 S54 M Coupe
    By jbh in forum BMW Cars For Sale / Wanted
    Last Post: 05-03-2004, 01:15 PM
