Bimmerforums Upgrade Garage The Tire Rack
Results 1 to 6 of 6
Thread: Question about Winter rims/tires for F30
    CT
    14 335i, 2x 98 C 230
    Question Question about Winter rims/tires for F30
    Hey everyone,
    I'm looking to get a relatively inexpensive set of rims and snow tires but am a bit confused by offsets and whether or not they will fit! Used to just buy all seasons and am finally joining the summer/winter tire master race.
    Right now I have the stock 403m's 19x8 ET36 and 19x8.5 ET47
    I plan on getting the Michelin X-ICE X13 225/45/R18.
    These are the rims I was looking at (Would like 18x8 on all four wheels). However, with an offset of just 29mm, does that mean the inner rim will sit closer to the car and potentially rub on the shocks? Or, will they stick out further from the wheel well? I would like to stay away from wheel spacers if possible.
    Any help or recommendations is appreciated!
    Nov 2013
    Stone Ridge, VA
    1995 BMW M3 Coupe
    For the fronts, the wheel will stick out 7mm further, giving you 7mm more clearance between the wheel and the strut.
    For the rears, the wheel will stick out 12mm further, giving you 24mm more clearance between the wheel and the strut (less wide width as well).
    CT
    Thanks pDubs. I will look for a wheel with a larger offset then. Also, for a winter set up having a non-staggered set up is recommended, correct?
    Aug 2002
    South Bend, Indiana
    BMW 525I
    A 32 mm wheel is not going to stick out of your wheel well though. We do have higher offset wheels that are available for the BMW. 7mm is about 1/4" and 12 Is 1/2" so it is not much different. The narrower rear tire will actually then not go out the full 12mm because the tires are narrower than the factory rear tires.
    If I can help with anything let me know.
    If ordering through the web site click through one of the banners and list "Jim" as a previous contact. The Tire Rack will direct a portion of the proceeds back to the the Bimmerforums.com site.
    Tire & Wheel Forum sponsored by The Tire Rack
    CT
    Quote Originally Posted by Jim@tirerack View Post
    So I should be fine with this wheel / tire set? There is a note in my shopping cart under the wheels: "Must use XL 225/40-19 on rear of vehicle for non-staggered set up." Not sure why it's recommending 19s on the rear?
    Aug 2002
    South Bend, Indiana
    BMW 525I
    If you are going to the 18" it will not matter. With the 19" you need the XL tires for load capacity. If you place the order online with Tire Rack just enter my name as a contact and I will review it and make sure everything is correct.
  1. E60 (2008) M5 Winter Rims/Tires for Sale!
    By razorblade in forum Wheels and Tires
    Last Post: 10-27-2009, 11:53 PM
  2. WTB: 17" Winter rims/tires for 335i Sedan
    By J3 L U N T in forum Wheels and Tires
    Last Post: 12-07-2007, 12:25 AM
  3. FS: Winter Rims/Tires for E46 or equivalent
    By beauport in forum Wheels and Tires
    Last Post: 01-22-2007, 12:59 PM
  4. What yall use for winter rims/tires
    By butta in forum 2001 - 2006 M3 (E46)
    Last Post: 05-10-2005, 10:24 AM
  5. For Sale E30, dash, winter rims/tires
    By SpeedyRacer in forum 1983 - 1991 (E30)
    Last Post: 03-27-2004, 01:56 AM
