I had a little leak coming from there so i replaced the oring gasket.
l do i need silicone?
Sent from my SM-N900T using Tapatalk
Did you remove any silicone from the old one?
Sent from my Z799VL using Tapatalk
It should not need silicone that's the o-rings job, silicone only adds to the total repair time. The book says coat the o-ring with lubricant before installing.
I am guilty of using silicone on my aluminum t-stat housing though. It wasn't the best quality machine work.
Finally got it to stop leaking. After gallons and gallons of water, two water pumps, two radiators, 3 thermostats and gaskets, one reservoir adapter, 3 res tanks, new clutch fan and blade,1 belt, a UV light KiT, and a BARs leaks copper alumaseal. I DID IT. NO MORE LEAK!!!
