Results 1 to 13 of 13
Thread: Actual speed on the instrument vs. shown speed at the MID
    Nov 2014
    Vena, Sweden
    1992 BMW 850ia
    This is something that has puzzled me since I bought my 850i -92. The speed shown on the meter, say 100 km/h (62.5 mph) is shown as 92 km/h (57.5 mph) on the MID (Hidden menu 8). The signal is likely to origin from the sensor in the final gear, is it not? I don´t know for sure or are there more than 1 sensor giving signals to the systems? Also is there any correction factor that can be adjusted to set the 2 indications equal and closer to the actual speed (Gps speed which is also different from these 2)
    //Peter
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    Speedometers almost ALWAYS show just a little bit faster than the actual speed. This is to put any speeding liability on the driver, not the manufacturer. If the speed limit is 120kmh and the speedo shows 120kmh, but you are actually doing 125kmh, you can say that it is BMW's fault since YOU thought you were doing the speed limit.
    '93 850Ci - Mineralweiß Metallic
    2001 740iL - Titansilber
    ALPINA B7 -Alpinweiß III
    San Ramon, CA
    850Ci, M5, Model-S P85D
    The speedometer error is a feature. I always assume somewhere around 5-7 MPH low at 60 MPH.
    See attachment:
    Tire diameter and revolution per mile is not a standard and will vary by tire manufacture, tire model and tread wear.
    The MID speed reading is an unconditioned reading based on the programmed tire revolutions per mile.
    However, the MID reading may be in error -/+ of actual as the actual tire revolutions may not be the same as the revolutions per mile programmed into the electronics.
    Hence, the only way to determine the actual vehicle speed is to measure it with an independent speed system, GPS, Radar, Lidar or other speed reference device.
    Drivers that religiously follow the speed-limit based on the speedometer are constantly driving below the speed limit!! And, they wonder why there is a long line of cars tail-gating!!
    Toronto, Canada
    BMW 850CSi
    So, do they get their measurements from the same sensor are there 2 different ones? And which does the odometer follow? The speedometer reading or MID?
    Nov 2010
    Central, MO, USA
    1993 BMW 850Ci
    There is one sensor at the output shaft of the differential, right side. All speed info displays are electronically derived from that input. I don't know if the odometer display is "dumbed down" like the speedo gauge, but I would guess not - in other words, I suspect it uses the best info available so the mileage is as accurate as possible. Just as the speedo gauge would err on the high side for liability concerns, the mileage value would not want to appear artificially low.
    Mark in mid-MO
    1993 BMW 850Ci 6-speed
    2011 Cadi CTS coupe 6-speed
    San Ramon, CA
    Quote Originally Posted by Dr. T View Post
    Just the one magnetic read-switch sensor in the diff.
    The speed signal is processed and distributed from the Body Control Module(EKM) to the various systems that use a Speed data, i.e., Instrument Cluster, DME, Throttle, Cruise Control, EDC, Radio, etc.
    The Instrument Cluster Odometer and Speedometer Displays are transferred over the Instrument Cluster Data Connection (data-link) from the EKM.
    The MID display also comes from the EKM but over I-Bus data connection.
    That I can tell from the ETM Diagnostic Manual, the Features for the Instrument Cluster analog Speedometer Display are added in the Body Control Module to the speed data transferred to the instrument cluster .
    The I-Bus speed data and odometer data transfers remains unconditioned as does the Speed A signals.
    Orlando, FL USA
    My car has the complete opposite speed indication. The speedometer gauge would show about 8mph slower than what the MID shows. Not sure why but I think it may have something to do with the instrument cluster swap from (originally in kilometer) Canadian to US model. I'm always doing like 80mph when the speedometer shows 71'ish. I always have to remember that when I'm driving the car.
    Dec 2007
    Dallas, TX
    Quote Originally Posted by ChrisFuture8 View Post
    What size tires are you running?
    The speed sensor picks up the axle speed and converts that based on the original tire sizes (circumference) to arrive at actual speed (+/-). If your tires are too "tall" i.e. the circumference is greater than stock, you will be travelling "faster" than what the speedo shows.
    Orlando, FL USA
    The car is currently rolling on 17s. I thought the smaller tires would actually register higher speed.
    Sent from my SM-G955U using Tapatalk
    Dec 2007
    Dallas, TX
    It is not just the wheel diameter. The aspect ratio is what will make the difference. For example, a 245/45/17 tire is "taller" than a 245/40/17 - the later will produce a lower "speed" with the same axle RPM. Same applies for 16, 18, 19, 20, and 21" wheels...
    Orlando, FL USA
    Hmmm, I see. Thanks for the clarification. So for folks who have upgraded to larger size tires greater than the original 16s but possibly with lower profiles, are there any calibrations that could be done to ensure speed indicated on the speedometer is accurate? How about folks that went to 19s and even 20s?
    Nov 2014
    Vena, Sweden
    1992 BMW 850ia
    I did a short trip to day measuring the speed. I had the speedometer, the mid and also a gps speedometer. I did set the cruise control at 3 fixed speeds 50, 70 & 90 km/h.
    Speedometer km/h MID GPS
    50 43.2 46
    70 62.2 67
    90 82.2 87-88
    BTW my tires are 255/55 on 16" rims.
    Jul 2015
    Melbourne, Australia
    1994 840Ci - M60, 6MT
    Quote Originally Posted by TxGR8White View Post
    See here for a comparison on tyre profiles and their corresponding diameter (or 'tallness' as described by TxGR8White) and the effect it has on the speedo.
    Simply comparing two 'standard' tyre sizes for the 17 inch wheel - 265/45/17 and 275/40/17 - results in a 2.8% variance in speedo reading as the diameter changes by 18mm.
    Here's the comparison table with dumb imperial measurements.
    Code:
    Specification  Sidewall  Radius  Diameter  Circumference  Revs/Mile  Difference
    275/40-17         4.3in  12.8in    25.7in         80.6in        786        0.0%
    265/45-17         4.7in  13.2in    26.4in         82.9in        764        2.8%
  1. E32 735i vs. 1992? Cougar at the local dragstrip
    By mrfatride in forum Kill Stories
    Last Post: 05-10-2004, 05:45 PM
  2. Can You Tell What The Diff Ratio By Looking At The Actual Gears?
    By jmciver in forum 1992 - 1999 M3 (E36)
    Last Post: 07-02-2003, 02:23 PM
