Results 1 to 3 of 3
Thread: E39 with LS swap - Brake Light Help
    Atlanta-ish
    E39 Wagon,'88 ZX10
    I swapped an LS3 into my 2001 525iT. It's currently running and reasonably complete but a couple days ago I realized my brake lights weren't working! I never thought to check since I didn't realize I had messed with anything...
    It turns out I had run the brake signal to the GM ECU, which was disturbing the brake pedal signal to the "lighting module". I disconnected it expecting everything to work. But now my brake lights are on all the time!?
    Does anyone have a clue where I should look? I've tried manually tinkering with the pedal sensor (ie. shorting, grounding, etc) with no luck. I don't think I have routed the brake signal to/through anything else so I'm a bit confused. Could it be ABS related?
    "In theory, there is no difference between theory and practice, but in practice there is."
    Oct 2008
    West coast
    '00 540 6.0/4L80e/S480
    My brake lights stay on all the time when the plug is disconnected. You might have a broken wire where the splice was made.
    Atlanta-ish
    E39 Wagon,'88 ZX10
    Silly mistakes. I had wired the brake light to the ECU signal wire as I mentioned. After fixing that, it still didn't function properly. In the end I started interrogating the brake sensor pins to determine what is missing and it didn't have power. Turns out I blew the fuse somewhere along the way,which was the first thing I checked! Anyway, new fuse and it works fine. I'm really not sure when the fuse blew or if I inadvertently fixed something else, but it works now.
    Thanks for chiming in.
  1. wow what the heck is going on with my brake lights?!?! help
    By gilliemar in forum 1991 - 1999 (E36)
    Last Post: 11-02-2012, 11:28 AM
  2. e39 540i 6spd check brake light (not taillights)
    By verdugo135 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-14-2006, 09:27 AM
  3. e39 smoked tails + additional brake lights
    By LavaBurns in forum 1996 - 2003 (E39)
    Last Post: 06-01-2006, 06:44 PM
  4. No brake lights. Help.
    By beeze in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-14-2004, 07:35 PM
  5. brake light help !!
    By p3rsian in forum 1991 - 1999 (E36)
    Last Post: 12-28-2003, 02:25 PM
