Page 6 of 7 FirstFirst 1234567 LastLast
Results 126 to 150 of 162
Thread: Someguy2800 turbo 400 adapter plate and questions
  1. #126
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by wagons ho View Post
    Everything, or the yoke?
    Yoke is from a mid 90's Grand Cherokee front axle. Dana 30, I believe.
    These are my first posts in FI and I doubt anyone is aware of what I'm working on. I should probably start a thread and introduce myself.
    The yoke. I was assuming this was a yoke from another application that you were having machined to fit on a BMW diff correct? Is this something your planning on making to sell? It would seam there is a demand for it.
  2. #127
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by Schitzo View Post
    I have a flange you can reverse engineer. It mounts a Spicer 1350 yoke (spicer part # 3-2-119) to a BMW 6 bolt flange. The flange is located within the BMW flange using a male pilot and also has a female pilot for the spicer yoke. I am in MN, twin cities area (though currently out of town until next Sunday) and can lend it to you to copy. I used this with an E34 M5 diff in my LS E39.
    That would be great, who made that and is it still availible? The two designs I am thinking about would be an alluminum adapter just like that to mount a spicer flange yoke, and I was also thinking of making a steel flange to bolt to the diff with a female pilot on the front and welding a 3" x 1350 driveshaft yoke on it to make a 1 piece yoke. Das Boost sent me a picture of the one he has that is made this way. I'm leaning toward the aluminum adapter since I can just get that cnc'd and not rely on my labor so much, but I think it would be more expensive.
    As long as there is a solution for the community that is all I am after.
  3. #128
    Minneapolis,MN
    2003 M5, 2014 535i
    A local machinist made it for me and yes, I still have it. I just supplied him with the BMW flange, the spicer yoke, and the tolerances including max runout.
    2003 M5 LSx l 6 Spd Manual l 4.10 LSD
    Build Thread
    The chassis must always be regarded as a means to an end and never as an end itself
  4. #129
    Apr 2016
    the great pacific n.w.
    540it, 540sedan, 540-6 s
    [QUOTE=someguy2800;29936654]The yoke. I was assuming this was a yoke from another application that you were having machined to fit on a BMW diff correct? Is this something your planning on making to sell? It would seam there is a demand for it.[/QUOTE
    I'm not trying to hold on to any secret, I just haven't made it on to this forum. Once I found this I moved on to my bigger project knowing i had a workaround for the rear of the driveshaft. The rest of the driveshaft is dodge truck which happens to have the same size inner bearing diameter as the BMW allowing a factory center support bearing. This all plugs into a 7260 standard mopar flange on the rear of my 727 trans with adapter to m62.
    As far as the yoke goes, I could have the work done and sell them, but most people here are talented enough to modify it themselves. My buddies shop has an end mill large enough to spotface that surface in 1 op. And quantity does cost less.
    All it needs is is the total yoke length at the nut surface shortened to match the bmw pinion by milling the nut face down. And a slight chamfer on the spline to match the bmw.20180106_143754.jpg
    The dust shield for the seal can be eliminated, or trimmed as the seal rides on it like a repair sleeve. With sheild, the sear inner diameter is almost the same, or back to the seal catalog for something else.
    My m62 project is my total focus right now, to be on here soon.
  5. #130
    DeWitt, Michigan
    '97 540i/6, '97 328i
    Oh sure man, bust out all of your pics and info for these guys you don't even know, when you don't tell us a damn thing on the E39 forum!! Lol
  6. #131
    Apr 2016
    Quote Originally Posted by tptrsn View Post
    Hey, my friend. We both know most of this info would be usless over there.
    When they start breaking stock parts, they can come over here for it.
    But then they probably already would be.
  7. #132
    DeWitt, Michigan
    Haha, probably! But I want to see the rest of the M62 to 727 adapter stuff over there.
  8. #133
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    Follow my builds on youtube and IG.
    www.youtube.com/thenameskam
    @thenameskam on IG
  9. #134
    Apr 2014
    Greece
    M3 e36
    A low 1/4 mile pass can also be done with a powerglide like this family man did.great to see this.
    https://www.youtube.com/watch?v=_0wrN_vh7rY
  10. #135
    Jan 2017
    Keokuk, Ia
    m50 turbo w123, 4g63 e30
    Is there an issue with the jagsthatrun adapter? I used one on my friends e36 that we ls swapped and it seemed like a pretty nice piece for the money.
    Edit: I suppose a lot of you are probably looking to use a 1350 joint.
  11. #136
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    Dburt also has a 6 bolt adapter he got in his thread.
    @thenameskam on IG
  12. #137
    Oct 2008
    Albuquerque
    a m3 on a 7675
    http://www.jegs.com/i/Sonnax/852/T35-GMFD-01/10002/-1
    It'll have to be turned down to 99.2mm
    And refilled for the 6 bolt pattern
    World record holder for a m52 stock bottom end.
    9.41@153 c4 auto 28" et streets, e34 3.64 gearset 900+hp
    E36 chassis irs world record holder 8.49@162
    Th400, e85, 7685, m50 intake 26.6 lbs of boost
  13. #138
    Apr 2014
    Greece
    M3 e36
    What is a good torque converter to use with the TH400 and your adapter plate ?
    I was looking at the FTI performance one to use,any feedback on them here ?
  14. #139
    Apr 2006
    Minnesota eh?
    86 325es
    Ideally your going to want to get one built to your specs. ATI, FTI, PTC, Coan, Protorque, Ultimate Converter Concepts would all be companies that I would consider that have a good reputation for turbo converters. There has been a huge amount of technological advancement in converters in the last 10 years mainly focused around making converters to work efficiently with turbo cars. For a custom 9.5" steel converter from most of the above companies expect to pay about $800-$1000. This usually comes with a 12 month guarantee that they will get it right for your setup. You tell them everything about your setup and they build one for you. If its too tight or too loose you send it in and they restall it and send it back for free. I am getting a billet bolt together converter from ProTorque. I am sold on them from watching what there stuff does with 2JZ's. I watched very closely a couple 2jz's with there converters this summer and was totally blown away with how fast they were able to get on the converter and spool on the line and how well they locked up going down the track. A good modern converter today should be able to stall at 5000 rpms, and still have less than 5% slip at 7000 rpms with 1500 hp. I've seen some turbo cars that are claiming 2% slip with 2500 hp.
    You could try ordering an off the shelf converter from Jegs or Summit racing but they were not built with turbo powerband in mind so I don't know how they will react. I have a TCI 9.5" nitrous converter I bought off someone local for $200 just to have something to mock up all my stuff so I may give that a try at lower power depending on when I get my custom converter built.
  15. #140
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    WOOOWEEE. bolt together. Gen X? I will be calling ProTorque soon... see what they have to offer. i hope its not the 2500 Genx bolt together converter lolol
    @thenameskam on IG
  16. #141
    Apr 2006
    Minnesota eh?
    86 325es
    Yes I'm getting the gen X aluminum bolt together. When I talked to them a welded steel gen X was 2000, a steel bolt together was 2250 and an aluminum bolt together was 2500. They are definitely pricey but I've seen them work and I see it as a long term investment as they will be able to rebuild it for whatever I do in the future. I spec'd all the parts for my trans for 1500-1800 hp for the same reason. I better get some better insurance on this POS lol.
  17. #142
    DeWitt, Michigan
    For anyone else who has a 4-bolt diff flange, I can verify that the Jags That Run flange is still available, and is a PERFECT fit. So good it almost seems like it was worth the money, lol.
  18. #143
    Jan 2003
    Charlotte
    Wow!! that thing will be ready for a big block and twin turbos!! ahhaha
    1998 Turbo M3 Nick G tuned setting 5 934Whp 849Wtq @27.88 Psi. ignite E90 setting 6=
  19. #144
    Nov 2005
    Linden, NJ
    F80, E36, X3"M"
    If your referring to Mike's 8 second pass that was with the samsonas dog box I believe. I think he broke 3 or 4 6 speeds before that.
    That was with a stock getrag 6 speed.
    97 M3 - 8.94@164 - 8 sec street machine, all BMW driveline, factory ECU
    02 M3 - 9.74@145 - Maximum PSI stage 2 turbo kit, stock motor, factory ECU
    16 M3 - 9.3@151 - Built motor/twins
    15 M3 - 9.2@162 - Built motor/single turbo/Ecutek
    BMW SOB's turbo E30 - 8.72@158.39
    follow our latest builds and upcoming events! - facebook.com/maximumpsi - instagram.com/maximumpsi
  20. #145
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by mike radowski View Post
    Good to know and great to see you back around!
  21. #146
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    Anyone make a trans brace yet?
    @thenameskam on IG
  22. #147
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    Ordered torque converter from pro torque... That hurt.
    @thenameskam on IG
  23. #148
    Aug 2012
    CT
    Twin turbo LS E36 M3
    Whos trying to go 8s?
    328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
    9.20 at 150 on 22psi
  24. #149
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by Kame36sedan View Post
    Send me dimensions and ill have some made..
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  25. #150
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    I don't believe the sonnax 6 bolt adapter I posted will work. But I ordered it anyways and will get it turned on a lathe to fit. I believe ID of the flange is 3.9" while the adapter is 4.25".
    @thenameskam on IG
  1. E36 FS: E36 OEM steering wheel, 6x9 adapter plates, and coupe kick panels
    By osuwari in forum Interior Lighting & Body Parts
    Last Post: 10-22-2023, 06:47 AM
  2. E36 Revised dss drive shaft with adapter plates and bolts
    By 97mreaper in forum Forced & Chemical Induction Parts
    Last Post: 09-29-2013, 10:52 PM
  3. E36 FS: 6x9 rear deck speaker adapter plates and OEM audio
    By osuwari in forum Car Audio & Electronics
    Last Post: 10-21-2012, 11:14 AM
  4. ANyone selling Turbo Kit for M3US '95? And questions
    By diegom6 in forum Forced Induction
    Last Post: 04-02-2004, 01:59 PM
  5. Replies: 17
    Last Post: 01-23-2004, 07:28 PM
