Page 4 of 7 FirstFirst 1234567 LastLast
Results 76 to 100 of 162
Thread: Someguy2800 turbo 400 adapter plate and questions
  1. #76
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    FYI got my flexplate today but neither side says engine side. You can still which way goes which though.
    Follow my builds on youtube and IG.
    www.youtube.com/thenameskam
    @thenameskam on IG
  2. #77
    Dec 2004
    Milford,CT
    95 M3
    Quote Originally Posted by dburt86 View Post
    I should really be buying 210's now because when you guys start going fast, ill cash out.
    I wonder if the junkyards have filled back up yet. I should grab a spare, just because.
    95 M3, 5.3 LS, PTE 7675CEA, TH400/Gear Vendors OD
    10.4@136 Pump gas at 3530lbs.
    Build thread
    http://www.bimmerforums.com/forum/sh...LS-Turbo-build
  3. #78
    Aug 2012
    CT
    Twin turbo LS E36 M3
    It takes some time. You gotta call them, and hopefully they are willing to check them, ect.
    But i just sold my last spare for 300$
    328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
    9.20 at 150 on 22psi
  4. #79
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    and didnt message me asking if i needed it? got it.
    @thenameskam on IG
  5. #80
    Aug 2012
    CT
    I posted it on here, in this subforum. Nobody said shit
    And now people are paying 700-1000$ for them lol.
    Ive sold 3 of them, all under 500$
    And now i dont have a BMW (except for my daily) so you losers are on ur own now.
  6. #81
    Nov 2017
    Blandon pa
    86 328 turbo,C7 Corvette
    Add me on the list too!
  7. #82
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by Kame36sedan View Post
    Perry, you should think about marketing these to the n54 crowd as well... If they have an 8 bolt crank that flex plate adapter will work. Now idk about the starter though.
    I looked into it and an N54 is a little different. Looks like it uses 2 extra bellhousing bolts and the starter is mounted to the block so I would need to figure out a slightly different flexplate and crank adapter. I am entirely willing to do it. If anyone is interested please send me a PM. I would just need to source and n54 block and crank.
  8. #83
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    Kit came in.
    Also picked this up.
    @thenameskam on IG
  9. #84
    Jul 2005
    PEI, Canada
    2001 330i
    That's quite a spill in the back of that SUV....
  10. #85
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    Yea thank God for the weather Tek mat. Little purple power and it came right off. Guy took the tailshaft plug out and gave me a cut up soda bottle that didn't hold.. lol
    @thenameskam on IG
  11. #86
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    anyone test fit yet? i was going to over the weekend but ran out of time unfortunately.
    @thenameskam on IG
  12. #87
    Jul 2005
    PEI, Canada
    2001 330i
    Perry,
    Would you be able to bolt the adapter plate backwards onto a ZF bellhousing to show the difference in size of the Chev bellhousing.
    I was just under my car looking at my current wastegate routing, and it occurred to me that I might have pipe in a location that this adapter plate might need to occupy....
  13. #88
    Apr 2006
    Minnesota eh?
    86 325es
    Sorry don't have one. Does this help? Note that the steel plate overhangs the adapter by about 1/4". The adapter is close to the same radius of a stock bell.
    I suspect most installs will want to trim the starter boss off the bellhousing for exhaust clearance, its not needed anymore. There is plenty of meat on the plate to trim as well if needed. After some people do some installs I may design some more clearance on that side for Version 2.0 if needed.
  14. #89
    Jul 2005
    PEI, Canada
    2001 330i
    Thanks Perry
    It will probably depend on the application, but that area is definitely a concern....possibly even for the downpipe.
  15. #90
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    Hood/fender exit. /Problem.
    @thenameskam on IG
  16. #91
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    Perry, do we need to run any Pilot adapter?
    @thenameskam on IG
  17. #92
    Apr 2006
    Minnesota eh?
    86 325es
    No the crank adapter has the correct pilot diameter for the torque converter.
  18. #93
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    gotcha. was talking to someone who spec's PTC converters. so far have been striking out with getting people to respond on what converter/stall to run lol
    @thenameskam on IG
  19. #94
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    Sandor sent me this pic on the book of face. Not sure if he messaged anything though.
    @thenameskam on IG
  20. #95
    DeWitt, Michigan
    '97 540i/6, '97 328i
    Figures that dude would be getting work done way faster than the rest of us... Looks like a BOP bellhousing on that trans, doesn't it?
  21. #96
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    yea it is. but only difference is that extra bolt hole. i have both a GM super bell and the trans still has the stock bell on it currently. still wonder if the stock bell is larger thant he after market bells.
    @thenameskam on IG
  22. #97
    DeWitt, Michigan
    I was figuring the factory bellhousing would be a bit slimmer since the aftermarket ones seem like they're thicker to contain exploding converters or something, but I'll be interested to learn what you find out about it.
  23. #98
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    well just looking at these pics you can see the aftermarket bell isnt as round as the stock.. a lot more space between the mounting holes and the actual casing.
    @thenameskam on IG
  24. #99
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    well got our answer.. time to break out the BFH lol
    @thenameskam on IG
  25. #100
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    some more.
    @thenameskam on IG
  1. E36 FS: E36 OEM steering wheel, 6x9 adapter plates, and coupe kick panels
    By osuwari in forum Interior Lighting & Body Parts
    Last Post: 10-22-2023, 06:47 AM
  2. E36 Revised dss drive shaft with adapter plates and bolts
    By 97mreaper in forum Forced & Chemical Induction Parts
    Last Post: 09-29-2013, 10:52 PM
  3. E36 FS: 6x9 rear deck speaker adapter plates and OEM audio
    By osuwari in forum Car Audio & Electronics
    Last Post: 10-21-2012, 11:14 AM
  4. ANyone selling Turbo Kit for M3US '95? And questions
    By diegom6 in forum Forced Induction
    Last Post: 04-02-2004, 01:59 PM
  5. Replies: 17
    Last Post: 01-23-2004, 07:28 PM
