Page 2 of 7 FirstFirst 1234567 LastLast
Results 26 to 50 of 162
Thread: Someguy2800 turbo 400 adapter plate and questions
  1. #26
    Mar 2012
    Renton, Wa
    98 m3
    When I'm back stateside I'll post my recovery times for the big turbo. I'm curious to see the comparison kev.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  2. #27
    Apr 2006
    Minnesota eh?
    86 325es
    That's the thing though, it will dyno 100 hp less but that's 100 less hp the chassis and tires have to deal with so you don't have as much traction problems. It's just going to be smooth power the whole way down. In theory you would think an auto would be slower on the big end but I've personally never seen a car trap slower going from a stick to an auto unless it only has 300 hp. Power glides usually trap a couple mph faster than a 400. A powerglide with a lockup converter even faster yet. A Lenco would probably be the fastest thing in a roll race. Foot to the floor the whole way and no converter.
  3. #28
    Apr 2006
    Minnesota eh?
    86 325es
    That's is what your competing for in roll racing isn't it, fastest mph? If it is ET a powerglide will win every single time.
  4. #29
    Jun 2004
    The D, MI
    97 M3, 98 328i, 13 Cruze
    Quote Originally Posted by vollosso View Post
    Might actually be pretty cool, I've got 6262 and 6766 data now that I think about it. Not sure exactly how to compare and represent it since acceleration rates are going to be pretty different but it's not my first rodeo.
  5. #30
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by Kevin325i View Post
    I have a 6870 with a 1.15 divided, a divided manifold w/ 1.625" I'd runners (volume),and 276 cams ..
    Really Looking forward to it..
    1989 535i - sold
  6. #31
    Jun 2004
    The D, MI
    I should have before and after the no lift shifting for both 6262 and 6766. We should be able to give a good representation of big vs little turbo time to torque on gear changes.
    Sucks that I'm not very quick at shifting.
  7. #32
    Mar 2012
    Renton, Wa
    98 m3
    Man with the knowledge..
    1989 535i - sold
  8. #33
    Virginia
    97' m52 turbo
    I am juggling deer hunting work and family this week so its a bit hectic. Tptrsn is getting the first, Das Boost is getting the 2nd, 4 other people PM'd me saying they probably want one. I am going to wait until Either Tptrsn or Das Boost get there's installed just to be 100% certain all is good before shipping any more. If you PM me your email I can send you the install instructions I made to give you an idea of how it goes together. I will try to post some pictures later, there are a bunch in Dburts thread.
    Can I get some deer jerky?
  9. #34
    Apr 2006
    Minnesota eh?
    86 325es
    Its easy, just go sit in a tree for a week with a gun when its 2 degrees outside and wait for one to happen by.
  10. #35
    Apr 2012
    Tampa, FL
    E36,E38, and E46
    Just thinking....if you had the slope of rpm/torque for a motor on auto with output torque you could see losses and calculate rms slope for the combo. Then side by side it with same rms calculation with manual. Side benefit would be the ability to calculate what would happen with any combination with a dyno run on a manual. At least for the slope calculated for that specific auto.
  11. #36
    Aug 2012
    CT
    Twin turbo LS E36 M3
    Once you guys realize your cars are only useful in a straight line anyways, then coming to terms with just embracing that is alot easier and the decision to go auto starts to make more sense.
    For example, heres my car going 126 to the 660ft.
    328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
    9.20 at 150 on 22psi
  12. #37
    Mar 2012
    Renton, Wa
    98 m3
    Looks pretty slow to me.. or maybe its just that seashell blue thats throwing me off....
    1989 535i - sold
  13. #38
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Quote Originally Posted by dburt86 View Post
    I agree, assuming you have compromised the handling of your car, and if you are jacked up in the back rolling on 275/50/15 marshmallow drag tires, you have. I jacked up on 275/40/17 drag radials and feel like I have compromised the handling significantly and am planning on lowering the car and running 275/40/17 r compound track tires rather than drag tires, with flares to accommodate the width. If my only interest was going fast in a straight line, I would probably do the 1960s 3 speed auto conversion. I am not ready to go there yet. Maybe I will get there -- I don't know, but after a few years of poor handling, I want to try better handling again and am working on that now ( flares, new rack, new tires).
  14. #39
    Aug 2012
    CT
    stick to roll racing
  15. #40
    Mar 2012
    Renton, Wa
    98 m3
    Issajoke
    1989 535i - sold
  16. #41
    Aug 2012
    CT
    I know.
    The gay color is what made that car awesome IMO.
    RIP lol
  17. #42
    Mar 2012
    Renton, Wa
    98 m3
    I know.
    RIP lol
    Hahah agreed. If it was on a street tire it would have been really hilarious.. next to some 70s camao with a blower..
    Actually surprised it came out of the hole so nicely on the IRS..
    1989 535i - sold
  18. #43
    Apr 2006
    Minnesota eh?
    86 325es
    Because torque converter
  19. #44
    A house
    '86 325e, '14 VW EPA
  20. #45
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by TheJuggernaut View Post
    You'll be happy to know I didn't see a damb thing last night so I went home one tag unfilled. Does that make the hurts better?
  21. #46
    A house
    The only thing that can make me hate you less is if you send me half of your haul (nicely butchered of course).
  22. #47
    DeWitt, Michigan
    '97 540i/6, '97 328i
  23. #48
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by tptrsn View Post
    126 to the eighth though?!?!?!? DAMN!
    Beats me by 11 mph. No joke.
  24. #49
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    Quote Originally Posted by FBpower View Post
    Whats your 1/8 or 1/4 mile time???also trying to be the hero on Bimmerforums i see .
    youre a Facebook tuner and never seen a dragstrip in your life,but still talking crap to other people.....
    dang....someone went to the trouble of making an account to confront a member?
    FB is srs bsns
  25. #50
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by milKt View Post
    FB is srs bsns
    You can tell they are from Facebook; such little focus and reading comprehension.
    1989 535i - sold
  1. E36 FS: E36 OEM steering wheel, 6x9 adapter plates, and coupe kick panels
    By osuwari in forum Interior Lighting & Body Parts
    Last Post: 10-22-2023, 06:47 AM
  2. E36 Revised dss drive shaft with adapter plates and bolts
    By 97mreaper in forum Forced & Chemical Induction Parts
    Last Post: 09-29-2013, 10:52 PM
  3. E36 FS: 6x9 rear deck speaker adapter plates and OEM audio
    By osuwari in forum Car Audio & Electronics
    Last Post: 10-21-2012, 11:14 AM
  4. ANyone selling Turbo Kit for M3US '95? And questions
    By diegom6 in forum Forced Induction
    Last Post: 04-02-2004, 01:59 PM
  5. Replies: 17
    Last Post: 01-23-2004, 07:28 PM
