So,my ‘man’ changed some control arms,and a steering arm thingy....the shimmy is bad both going up through 60mph and braking at speed....super death wobble....I noticed the gaps between the wheels and back of the wheel well (arch) are significantly different....one side I can get two fingers in, the other less than one....any ideas,has he put the arms on the wrong sides ?....etc....it’s getting boring now....cheers fellas....
That doesn't look right. Was the car ever involved in a collision? There really isn't any way you can install the arms "backwards". Are you sure they are the correct arms? E31 not interchangeable with anything else when it comes to control arms. Really can't help you without you doing some homework, like seeing what the part numbers of the arms are..
'93 850Ci - Mineralweiß Metallic
2001 740iL - Titansilber
ALPINA B7 -Alpinweiß III
Cheers, I wondered if it was the lower control arms that were fecked...will do some more research .I kinda just left it with them instead of overseeing the job....big mistake.....
You still never answered if they replaced both upper and lower. How about putting a list up here that shows exactly what has been replaced? That way we won't all be playing a guessing game with you.
Cheers,still trying to find out...doh !
Confused. You apparently had the car in the shop to get suspension work done. You got the car back, and while driving it you noticed something not right. Did you not pay for the repairs? If so, you should know what was replaced and what wasn't. Doesn't seem that difficult...
I didn’t pay for the repairs,yet....a mate is doing it as a ‘favour’ .I will report back when I find out what’s gone on...I suspect upper arms only, and this steering thingy cheers
Wheel Alignment ? if upper control arms were done they need to be loaded then tightened to spec. If lower were done this doesn't need to be done.
I have the same problem with left wheel sticking closer to the fender.
Allignment didnt fix it and I have no clue what it is that makes it
Anyone figure this out yet??? I just had some suspension work done and have the same issue. Passenger side wheel is also set back in the wheel well.
Usually, A wrong but similar arm does that, Don't recall exactly but it was a 5 or 7 series arm that made it look like the photo above.
Didn't change upper, only lower with Lemforder from ECS.
You think I could be that??
I had a similar issue, changed all the front suspension, shimmy still there. In the end I fitted new brake discs and the problem went away. The old ones weren't warped at all so not sure why they caused the problem.
Did you ever figure out what was the issue? I’m having the same issue even after verifying the right part numbers.
