Results 1 to 3 of 3
Thread: 2 Pole Plug Housing wire terminals?
    Mar 2016
    Houston, TX
    1989 635csi
    I can't find any info on what terminal type I need to get for the 2 pole plug housing (PN 12521706091). I'm replacing my fuel injector terminals with these but I need the terminals PN to get the wires into the plug housing. Someone help!
    Mar 2016
    Houston, TX
    1989 635csi
    Ok, I've found the answer. the 2 pole plug housing for our cars is PN 12521706091, it is a Bosch EV1 type Fuel Injector connector. These connectors are also used on many other sensors on the car including the coolant temperature sensor. These plugs do not come with the electrical contacts so you have to order those separately. The electrical contact PN is 61131357705 and shows up on ecstuning as a genuine BMW part for a whopping $3.43 PER CONTACT. After a little bit of research I found that these bosch connectors are pretty common so you can find the electrical contacts from non-bmw sources. I ended up purchasing the contacts for $0.45/per from http://www.240turbo.com/blackvinyl.html and tested them out last night to fit perfectly in the housing. I'm headed out tonight to harbor freight to hopefully find an 'open contact crimp tool' to do a professional job on crimping the wires in the contacts which I recommend to anyone else doing the same job.
    PA
    2007 328i, 1987 635CSI,
    I’ve used connectors from Injector RX in Houston with good results. They come with up to 8” pigtails assembled, ready to go for less than $5 each. No reason to buy anything else.
    Good Luck
    Tom in NV
  1. Help on where to buy plugs and wires...
    By JLMann82 in forum 1988 - 1996 (E34)
    Last Post: 02-23-2005, 04:29 PM
  2. Part # for Euro Headlaight plug and wire connectors
    By chuck90m3 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-31-2004, 01:19 AM
  3. Plugs and Wires ?
    By [///M3]Stud in forum 1992 - 1999 M3 (E36)
    Last Post: 02-27-2003, 03:24 PM
  4. 325 es still sputtering after changing the plugs and wires HELP!
    By ekdemos in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-03-2003, 03:13 PM
  5. new spark plugs, with wires or without
    By airjordan23 in forum 1992 - 1999 M3 (E36)
    Last Post: 11-28-2002, 03:31 AM
