I have a 2011 535GT that has factory 245/45/19 run flat tires on factory wheels on all 4 corners. My question is will factory 19" wheels from a X6 fit the car? and the wheels have 255/50/19 tires. Will this be an issue? Thanks
Hello and welcome to the forum! Yes, the 19" rims will work just fine; I don't foresee the tire sizing being an issue either. Other members will likely chime in as well.
888.280.7799 | 6am - 5pm PST
So are you saying that the offset for the OEM X6 wheels will be the same as the offset for a 2011 535GT? I figured the tire size would not be an issue just want to make sure the offset is the same. Thanks
The tires are too big. They are 1.3" taller than stock. The X6 wheels offset is a little lower than the 5Series but should work. Just go with a 245/45R19 tire.
If I can help let me know.
X6 wheels will not work! The rear hub of the X6 is larger.
I guess maybe a centering ring would fix that.
