Results 1 to 3 of 3
Thread: 2011 750Li F02 - Sunroof stuck - manual override not moving it
    Salt Lake City, UT
    1992 E32 735iL
    My sunroof will not close or open. I have attempted the roof "reset", and while pushing the sunroof button in 'vent' mode, the motor started a process about 25 seconds in, but then would not stop at 2min. I released the button. Now I can hear the motor when pushing up, or forward, but not back to 'open' the roof. All the while, the roof does not move.
    I opened the light panel to access the motor... manually attempting to close with the allen wrench tool did not move the roof, either. Any ideas?
    Salt Lake City, UT
    1992 E32 735iL
    Thank you for viewing... all 86 of you so far. Any fix suggestions or assistance would be greatly appreciated. Thank you.
    Texas
    '01 s54 M Coupe; '11 750
    There are multiple variants of the reset/learning functions. Have you tried all of them?
    You might also consider disconnecting the battery for 30 minutes then giving it another shot.
    Did this error occur randomly, or after altering the programming?
    If randomly, you might want to check the track for debris (or lubricate the track if you use it often). Sorry if that's obvious, but sometimes the the culprit is as banal as a small acorn wedged in a weird place.
    Sent from my SM-N920I using Tapatalk
  1. Rear window stuck down, manual override?
    By ekimp in forum 1991 - 1999 (E36)
    Last Post: 10-13-2012, 05:42 PM
  2. Manual Sunroof stuck!
    By e30enthusiust in forum 1983 - 1991 (E30)
    Last Post: 06-17-2012, 12:54 PM
  3. Sunroof stuck in "tilt up" motor runs but will not close
    By e38740il in forum 1996 - 2003 (E39)
    Last Post: 08-07-2011, 12:16 AM
  4. Sunroof stuck open, can't close manually...
    By Theodore in forum 1992 - 1999 M3 (E36)
    Last Post: 09-25-2010, 02:03 PM
  5. Sunroof Stuck... Can't close it manually. Rain this week... Help!
    By manynames3 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-10-2010, 08:18 AM
