Results 1 to 5 of 5
Thread: e36 m3 bilstein suspesion
    Oct 2017
    Houston tx
    1999 bmw 323is
    was wondering if anyone know if the B12 Pro-Kit Suspension System
    fits a 99 e36 323is?
    Oct 2003
    Seattle
    99 M3
    Yes that could be a figment, I say could because the set I looked at on the ECS Tuning website indicated 1995M3 and 1996M-1999M3 fitment.
    The 318/325/323/328 use the same diameter spring ‘hat’ as the 1995M3. The 1996+M3 has a slightly smaller diameter upper spring diameter and ‘hat’.
    Worst case is that you need to purchase the 1996+M3 spring ‘hat’ and upper spring pad.
    I would recommend the E46M3/convertible Rear Shock Mounts and the Z3 Rear Shock Mount Reinforcement Plates.
    Additionally, the 1996+M3 Strut Tower Reinforcement Plates.
    There is an E36 323/325/328 Bilstein B12 Pro Kit # 46-180957
    https://www.turnermotorsport.com/p-2...nsion-package/
    I still recommend the RSMs and Reinforcement Plates mentioned previously. Also order and install the appropriate paper body gaskets.
    Oct 2017
    Houston tx
    1999 bmw 323is
    Thanks for all this info and yeah I know the have a set for the 323 but I got a set for the m3 for 200$ and that’s why I was asking if they would fit
    Oct 2003
    Seattle
    99 M3
    Are you familiar with www.realoem.com?
    Do you know what Model Year these were on previously?
    You can see the part build-up in these types of images (from realism.com), this is for a 1999 M3 (really, 1996-1999)
    http://www.realoem.com/bmw/enUS/show...diagId=31_1250
    You should run the M3 spring “hats”, this is the same image for the 1995M3 (same spring “hat” diameter as 318/323/325/328)
    Oct 2017
    Houston tx
    1999 bmw 323is
    They came off a 1997 m3 I did try them on after the I purchase them. but I’m off about 4 to 5 in for them to bolt on
  1. E36 95 E36 M3 Bilstein Shocks and H&R OE Rear Springs $75 Shipped
    By jdhaustin2 in forum Suspensions, Springs & Shocks
    Last Post: 06-10-2010, 05:44 PM
  2. E36 95 E36 M3 Bilstein Shocks and H&R OE Springs
    Last Post: 06-07-2010, 02:21 PM
  3. E36 FS: E36 M3 Bilstein Sport Shocks/Struts $300 - complete set
    By Badgtho is back in forum Suspensions, Springs & Shocks
    Last Post: 05-18-2010, 06:23 PM
  4. E36 E36 M3 Bilsteins F&R California CHEAP
    By Jrdeamicis in forum Suspensions, Springs & Shocks
    Last Post: 04-09-2010, 06:45 AM
  5. E36 96-99 E36 M3 Bilstein Sports - $500
    By desynch in forum Suspensions, Springs & Shocks
    Last Post: 12-08-2009, 10:49 PM
